Question about DeLonghi EN680.M
DeLonghi EN680.M Nespresso Lattissima Single-Serve Espresso Maker, Metal (by DeLonghi - EN680.M model)The water light button is not blinking
5 Suggested Answers
SOURCE: Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Posted on May 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: Replacing the pipe unit
the pipe will pull on and push on. It should have rubber connections. I first would remove the 4 screws on bottom. Should only need a screwdriver and a needle nose pliers. I haven't seen a diagram or repair manual yet.
Posted on Oct 24, 2009
espressonist
  • 1711 Answers
SOURCE: My delonghi lattissima is not piercing the
First you need to check the capsule container. Make sure that there are not any coffee remains both the liquid of dry coffee since will blocked the capsule to sit in proper place and thus to be press correctly. If you find anything you need to clean them very well with a warm wet sponge (remove machine from plug).
The second possibility is that one part of the lever and capsule container have brake either a plastic part or a metal rod or a spring moved out of place. In this case you need a new capsule container which you can find in this link.
Here is also you machine parts diagram.
Posted on Jul 31, 2011
  • 115 Answers
SOURCE: Hi, I have a DeLonghi
Hi. sounds like an ECU problem. Take to a repairer. Dazza REPAIRER
Posted on Sep 24, 2011
Delonghi
For De\'Longhi En520.W Nespresso Lattissima Plus Coffee Maker Team De-Brewerz.com says:
1. Your coffee maker might suffer from water pump, water sensor or PC board failure. Claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Now you can order all De Brewerz Stuffs online in India @ www.fabkaart.com
Aug 29, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try filling both water and the milk container with the correct decalcifying solution - just slit the 500 ml that results from the 1:1 mixture and - without the coffee capsule - press the cappucino button. Instead of cappucino you will get the decalcifying solution running through the entire system including the connector for the milk container (unlike the recommended decalcification method where you use the extra nozzle). Good luck - worked for my machine which only produced steam but no milkfoam...
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
How obtained A download a manual?
Go to this site to get a manual. It is listed under CUSTOMER SUPPORT. :-) Here is the link to the website. http://www.delonghi.com/en-us/products/coffee-and-espresso/coffee-makers/nespresso-system/lattissima-pro-en-750mb-0132192224?gclid=Cj0KEQjwrqieBRCln82Rgufz7I0BEiQAPNjAIwPVQ5e68guS8rRE8O_Lry_tcDMQOapRV2KTlEHJuIkaAqS_8P8HAQ Lattissima Pro EN 750 MB
Jul 20, 2014 | DeLonghi Coffee Makers & Espresso Machines
Cappuccino and latte macchiato buttons blinking
The unit is heating the steam - the lights should switch to contant once the right temperature is reached. Make sure to always descale the machine if the cappuccino button light turns orange.
Mar 29, 2014 | De'Longhi Nespresso Lattissima Plus...
How to programme it for larger cups of coffee
Press/Hold the large cup button until u reach the desired measure of your coffee... Release it when u think it is enough for your large cup..
Feb 09, 2013 | Nespresso DeLonghi Lattissima Plus...
DeLonghi EN680.M Logo
168 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
