Question about Zanussi ZHQ575 Electric Double Oven
I want to replace the top grill element in a zanussi zhq 575
How do i go about it
  • Anonymous May 10, 2009
    grill element on zanussi fm 9232 needs replacing
  • Zanussi Master
  • 3,463 Answers
Regardless of wether it is built in or free standing you will have to remove the rear panel, possibly the top cover as well.
The element may be fastened from the inside of the oven .or on the outside at the rear, depending on which way the screws have been fixed.
Undo the fixing screws, disconnect the wires taking note of the connections ,this is very important, and withdraw the element from inside the oven.
Fit new element in reverse order, it is a fairly straight forward repair to do..
Plz rate my solution.Thanks.
Posted on Jan 03, 2009
Our ancient Zanussi ZSA15 oven isn't working. Everything else is - lights grill etc. Guess it sounds like the element around the fan. Can I fix this (unlikely), is it worth replacing?
ONCE AGAIN, A SIMPLE GOOGLE SEARCH!
I WISH PEOPLE WOULD LEARN TO USE IT INSTEAD OF BOTHERING US!!!
Zanussi ZSA15 oven parts
Google
This is the official Zanussi parts website.
Click on Cooking then select heating elements.
Official Zanussi Site Parts Accessories for Appliances
You'll need to find your Appliance Product Number, the page tells you what to look for.
On this website, your ZSA15B or ZSA15W (probably stands for black or white) Is listed. It lists 3 different replacement elements.
Zanussi ZSA15W Elements
Sep 21, 2016 | Zanussi Ovens
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
The grill on Zanussi FM9232 keeps blowing the main fuse
the grill element needs replaceing or you have a wire on the grill element thats come off and touching down to earth
Sep 07, 2011 | Zanussi ZHQ575 Electric Double Oven
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
456 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
