Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Reset button delonghi pinguino
When we plug it in and switch it on, it just does three beeps at us. Is there a reset button?
SOURCE: FE Light
You need drain the water and then function normally.
Posted on Oct 02, 2007
  • 9 Answers
SOURCE: Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Posted on Jun 08, 2008
  • 230 Answers
SOURCE: delonghi pinguino k900
Try this link. I do not see a "K900" but maybe it is a start.
http://www.delonghi.com/Int/USA/customer.html
Posted on Jun 16, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: delonghi pinguino pac l90 manual
Here you go!
http://www.manualnguide.com/download/manual-guide/delonghi-pinguino-pac210-portable-air-conditioner-owners-manual.html
Posted on Aug 19, 2008
SOURCE: Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Posted on Oct 02, 2008
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Manual delonghi pinguino
Uoy need the model number to find the correct manual. Download at one of these links.
Pinguino Air to Air PAC AN95
Free DeLonghi Air Conditioner User Manuals ManualsOnline com
Aug 19, 2014 | Heating & Cooling
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
I turn on my ps3,tv displays message..invalid format... what can cause this,how to fix it?
Hi there, your display needs resetting back to standard resolution, please follow my guide on how to do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
I own a delonghi pinguino eco PAC T120 and when i switch it on it shows 'ft'on the screen. it doesnt turn the air on. what can i do?
Probably, the
"ft" means to check the filter. If your filter has not been cleaned in a while, it cannot breathe,and operate properly.
Dec 22, 2009 | DeLonghi Pinguino PACL90 Portable Air...
My ps3 will boot up and the green light is on but i cannot see what is being displayed. i once changed the settings from the three prong to HDMI cable and since then i have not been able to view anything...
1. Turn off the PS3
2. Plug in whatever cable you are going to use
3. Hold the power button down until it beeps once followed by two quick beeps
This resets the display settings to defaults and you will see the picture again.
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Not connecting to tv
If you changed the video output settings when you connected to another tv then you will have to reset it.Switch the ps3 on and hold the power button until it has beeped three times(not including the first power on beep).This should open a menu,choose option 2,this will revert your system back to default settings.Hope this helps
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Heating & Cooling Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
