Question about Robin Subaru SGX7500E Portable Generator
My Subaru SGX3500 3,500 Watt 7 HP OHC EX21 Gas Powered Portable Generator runs very rough and stalls out. It is new. We started it for the first time after sitting for about a year. Could it be the
The unit worked and we ran it long enough to make sure it generated the electricity we needed for the house. But it continued to run very rough throughout the time we were using it. Chugging a lot and threatening to cut out.
3 Suggested Answers
  • 1388 Answers
SOURCE: Small 1100watt Generator (Suburu by Robin) Had not
When the engine is not running the throttle is held wide open by the governor arm/spring. Varnish in carb most likely kept throttle stuck in the open position until small amount of gas in carb was consumed. Check your linkage /governor spring to make sure it is working properly. With engine off you should be able to move throttle closed easily and it should go to full after you release. After you adjust governor and are ready to start engine be ready to manually control throttle if engine begins to run at full speed. Runaway engine could have damaged the centrficical force style governor mech inside of the engine. As the engine starts have your finger on the throttle linkage, push the throttle open and you should feel the governor push against your pressure. Now as for the carb itself, blowing air thru the orifices is not sufficient. You must clean fuel passages with fine wire removing debris being carefull not to distort passage (make larger). Check that fuel runs from tank to carb with out restriction. Finally empty tank of fuel and use premium fuel for a while to help get power back up to normal. Good luck
Posted on Nov 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: generator turns on and runs
Hi and welcome to FixYa, I am Kelly,
Since I don't have a model number to work with I am going to assume this is a generator with brushes. (I need your model number!)
Having said that... TRY THIS:
1. Plug in an electric drill to the output power plug and turn on the output power switch with the generator running.
2. Squeese the drill trigger switch and rotate the drill chuck as fast as you can. This will flash the field of the generator and often output power starts right away. NOTE: When power starts it will try and twist the drill chuck out of your hand. Just let go of the trigger and the drill chuck.
If you have an inverter type power head the steps are different for flashing the field. The easiest way is to do a male to male power cord from utility supply power connection and turn on the output power switch to re-establish a field in the PMG of the rotor.
There are other steps but without a model number this is what I am sending off at the moment. Respond with a model number if the steps above do not work and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Aug 28, 2011
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Jan 21, 2016 | Electrical Supplies
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
I have a 4500e duromax starts up and runs then shuts off clean carberator same problem looking for suggestions
On the WEB
manual-duromax-elite-mx4500e-manual ' Generator Nation
www.generatornation.com/tag/manual-duromax-elite-mx4500e-manual/
DuroMax Elite MX4500E 4,500 Watt 7 HP OHV 4-Cycle Gas Powered Portable Generator With Wheel Kit & Electric Start Reviews. By Generator Man Posted in ..
Jul 31, 2015 | Cars & Trucks
Engine starts runs rough,then quits before you can put a load on generator,starts with half chock,will not run without half chock,and even half choke runs rough,and then quits
this is down to fule shortage strip card and all fule pipes clean the tank on off tap and any filters fitted also check all the jets inside the carberetor blow out with comprest air,,,dont go pokeing wire into any jets!! that could wreck the jet, but its all down to fule shortage
Jan 23, 2010 | Generac 5622 GP Series GP5000 6,250 Watt...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Robin Subaru SGX7500E Portable Generator Logo
110 people viewed this question
Top Robin Subaru Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
