Question about Canon D420 AllInOne Laser Printer
Reset canon imageclass d420
Refill toner
  • 57 Answers
SOURCE: canon ir33ooi-toner
On a Canon iR3300 you do not remove the toner to refill. You have to get a new tube of toner. Open the front door. Release the developer with lever coloured. Slide out the developer unit till it stops. Insert the new tube on the developer and best way to do it is to follow the pictures instruction on the toner cartoon box. Also there the prccedure on the copier display how to do it.
Posted on Jun 12, 2008
cene765
  • 787 Answers
SOURCE: canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
Posted on Oct 05, 2009
canontech
  • 1219 Answers
SOURCE: canon imageclass mf 6530 blank pages change toners
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Posted on Jul 19, 2010
johnsonbing
  • 10 Answers
SOURCE: my printer laser canon lbp
this might work for you
Posted on Aug 20, 2010
  • 49 Answers
SOURCE: Refilled Cartridge, still says out of toner. How do I reset it
be sure the cartridge is installed correclty
http://www.quikshiptoner.com/catalog/canon-imageclass-mf3240-toner.html#How_to_Replace_the_Toner_Cartridge_in_a_Canon_imageCLASS_MF3240_Printer
Posted on May 21, 2012
My canon copier D420 had a paper jam. can't get the copier to work now.
Try checking the paper path, there might be a broken or loose gear in there, a bent wire or stuck debris. If you done this and all seems ok but the error message keeps flashing, try to do a hard reset. That usually clears off error messages. If nothing happens, you might need to call a technician.
Feb 07, 2013 | Canon New Usa Imageclass D420 Laser...
RESET TONER
If you refilled the toner cartridge and your sure you got the toner in the right place (tank is under the handle); there's a small rectangular box on the tank. This is the location of toner sensor. Trim a piece of aluminum foil or 'refrigerator magnet business card' to fit in that spot and tape it down.
Your toner cartridge status should now be full
Apr 23, 2012 | Canon D420 AllInOne Laser Printer
Red alarm light flashes..Reads ...prepare a new drum
your drum unit is near end of life.
you will have to buy something like this
http://www.dura-toner.com/canon-ep87-drum-unit-cartridge-imageclass-mf8170c-mf8180c-drum-ep87dr.html?AdID=352--EP87DR-R
i am showing you just for example, search local stores for cheaper.
you can also give it for recycle, just find some toner refilling company near you.
Sep 19, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Refilled cartrige on MF3240. Says out of toner. How do I reset it?
Hi there
This is because of the refill you can try going to your menu and then reseting it, the old chip still see that it was emty.
All the best Pineworks
Apr 28, 2010 | Canon MF3240 imageCLASS Laser...
Install Cartridge error on Canon D-320 Copier
Try opening the right door and re-closing it to reset.
Also, be sure that your "new" cartridge is really new and not a low quality refill.
good luck
Dec 05, 2009 | Canon imageCLASS D320 Digital Copier
D880 printer won't put toner on the paper (prints blank)
make sure the replaced toner is in good condition and is placed properly in printer refilled toner often alarm about low ink but work properly
Jul 22, 2009 | Canon imageCLASS D880 All-In-One Laser...
All you have to do is open the left side cover (two screws on the front and two bigger ones on the back) and disconnect the black connector with four purple wires as shown on the picture:
http://i1230.photobucket.com/albums/ee500/stark5667/4cb7e58b.jpg
Apr 28, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Ho to refill Cannon Imageclass X25 toner?
You're only asking for problems trying to do it yourself. It' extremely messy, and more involved than simply adding new toner. and the refill kits are a scam. Find a reliable supplier, and get a remanufactured unit with a guarantee, if you're looking to save money. Cartridges are designed to go 1 cycle, and then require a new drum, cleaning blade, doctor blade, bushings, toner, etc. The cartridge includes not only the toner supply unit, but also a waste section, that, even if you were to refill somewhat successfully, the section will begin to overflow, causing further problems. Cut your losses.
If you're local. I can help:
http://www.hotfrog.ca/Companies/Sandman-Sales-Service
Jan 18, 2009 | Canon X25 Toner Cartridge for imageCLASS...
Refill Image Class 4150
i haven't found a replacement that is non-canon.
Feb 01, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Canon D420 AllInOne Laser Printer Logo
156 people viewed this question
old marine
old marine
