Question about PSC PN: 5317HP3455 Scanner Barcode Scanner
How configuration this type of barcode scanner at SUN system???
Just for your information: SUN System: Workstation V0705D. port: PS2 (sun system), not USB. may i know, how to configure at this Sun system??? any patches file needed??? please advice.
3 Suggested Answers
SOURCE:
  • 244 Answers
SOURCE: Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Posted on Nov 05, 2007
SOURCE: QS6000 Plus barcode scanner
you can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Posted on Nov 08, 2007
Drivers for ms5145
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
Jun 06, 2012 | Metrologic Instruments Eclipse MS 5145...
How can i access my internet in my phone? its myphone Q19i to sun
To Enjoy Internet features using Sun Cellular Network, you must configure and activate your GPRS to be able to use this feature. Please follow this instructions
Activate your GPRS
Two ways to activate your GPRS:
1. Text ACTIVATE to 2300
2. Call 200 using your Sun phone or 395-8000 via landline, and a customer service representative
will assist you
Configure your Handset
Two ways to configure your phone:
1. Text SUN GPRS to 1200.
2. Manually configure your handset. Click Here!
For more information, go here : SUN CELLULAR GUIDE
Good day...
Sep 09, 2011 | Cell Phones
How do I connect the main unit to the front end?
Which main unit to Front end of what?
Sorry to say,but your question is not very clear about which product you need support.
Thus, please give some more detail on your product whenever you ask any support so that the experts can search the exact products and provide better support as there are hundreds of similar products in the market.
Please give exact Make and Model number of your product and also some more detail on your problem so that we could identify your issue better ant give appropriate solution.
Thank you.
Aug 24, 2011 | Computers & Internet
HOW TO PROGRAM LS4278 SCANNER TO CONNECT TO KEYBOARD CABLE CONNECTION
Hi, i want to connect mt LS4278 with micrologix directly using the 8 pin ps2 port.
so any body can give me the pin configuration for making the cable RJ45 to 8 round pin.
pankaj
Jan 31, 2011 | Symbol LS 4278 Barcode Scanner
When i connect my netgear DGN2000 to the dsl and ethernet, i still can't access the internet, what can i do to fix this?
Router set up
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 20, 2010 | NetGear DGN2000-100NAS Router
Get usb device unreconized when I plug wcs3900 into usb port
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 05, 2010 | Wasp Nest WCS 3900 CCD Barcode Scanner...
Barcode Sanner not working
just connect the ps2 port of your keyboard with female port of bardcoder & then connect the barcoder port to kbd ps2 port
Nov 06, 2009 | Symbol MC9090 Barcode Scanner
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Reading codebars
A solution to your problem would be to use usb cable to connect the scanner to the POS system. I have had a similar issue in the past where the IBM pos system did not like the cable that the customer had and we've got around this by using usb instead.
I hope this helps you although it may not be the kind of answer that you were looking for,
Mar 24, 2009 | Symbol LS2208 Handheld
The scanners won't scan information after being programmed
I would scan default barcode again. If you are using PS2 connectors. Scan barcode for PS2 keyboard. And USB for USB connectors. Most likely it is not seeing the device. Or treating as a keyboard as it should.
Jul 06, 2007 | Symbol Hotshot LS2106 Handheld
Computers & Internet Logo
78 people viewed this question
Top PSC Computers & Internet Experts
Thomas F. Schneider
Tom Chichester
Terry
Terry
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
