Question about LG Televison & Video
My plasma pdp50t30010 back light does not turn on please advise
Back light does not come on power supply is ok
likha
  • 790 Answers
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: power shuts off and blinks red .
I had a similar problem, but mine didn´t switch on when pressing on button, I had to take the back cover off and hit the relays, it seems they get stuck, and are difficult to find to replace them. Now it has been working during almost a year with no problem at all. Mine is 4 years old.
Posted on Apr 08, 2008
  • 35 Answers
SOURCE: My samsung plasma suddenly made clicking noises and tuned off
I wish to tell the world about the simple cheap fix for your plasma! . Please let me know if I helped. I have a 50" Plasma that deicded after a year it didn't want to turn on anymore. It just blinked red LED. Which made me see red! It took me a year to find this inexpesive fix I hope this information will be helpful to you.... These are spendy items and none of us were thinking that after a year (seems like a scam to me) the TV just won't turn on anymore.... Then they say your no longer covered under warranty or you are and they send you to some repair shop 1-2 hours away and always and I mean always tells you the part is on back order.
Lukster is right it is a power supply problem. However you don't need a new board nor do you need to pay someone a ridiculouse abount of money to fix this. I fixed mine for 40 cents.
You more than likey have bad capacitors.
Unplug the TV from power. Remove the back cover. (some models require a star srewdriver) You power supply board is right in the center. A bad cap is bulgded or raised. A good one is flat. caps have an X on the top of them. More than likely you will see a bulding or just straight raised edges on the X on the top of the caps. Cap 3300uf 10v is the ones you are looking for. Once you find them replace them with 3300uf 16v caps. If one cap is not raised replace it anyway. These caps need to be a higher voltage that why the tend to pop. 16V is plenty, don't go any higher in voltage than that.
The caps need to be soldered on. You have 2 options do it yourself or unplug all the wire harness from the board then unscrew the board take your power board (dont forget your new caps) down to a pc repair or tv repair and have them solder them on for you. It will take less than 10 minutes. I do recommend putting the board in an anti static bag. You can buy these caps at radio shack or buy them on ebay.
After you get it repaired replace your board plug all power supply wire harness back onto the board (I recommend numbering the wires as you remove them), replace the back panel cover. Plug her in and fire her up. and BAM it works. then turn it on and off a few times in complete amazement at how simple and inexspensive this was to do. Then get angry cause your repeated calls to tech support was wasted breath.
Semper Fi
Posted on Feb 07, 2009
SOURCE: 50' Plasma won't turn on. No power.
hi, i have the same unit and did the same as yours i open it up and it had a blown fuse on the main board there four fuses. mines had ones of the two fuses on the right lower corner of the main board blown out i replaced it and worked fine again.
Posted on Apr 26, 2010
Testimonial: "Ours ended up being a blown fuse too. $2 and we are back in business! YEAH!"
Sony bravia klv32bx311 screen half is dark sound is ok
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 04, 2015 | Sony Televison & Video
My hitachi plasma tv model 42PD5000 wont turn on.the red light by the switch wont turn on either.i have checked fuse on plug which is ok.please advise what may be the problem. Thanks Roberto
Hey,
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.if otherwise, the power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help to fix the problem and do take care in handling the problem.....
May 26, 2011 | Hitachi 42HDS69 42 in. Plasma Television
THIS TV WILL JUST SHUT DOWN WHILE WATCHING, FIRST IT WAS JUST EVERY SO OFTEN AND I THOUGHT IT WAS CABLE. IT WOULD GO OFF THEN COME RIGHT BACK ON, BUT NOW ITS HARD TO GET IT TO COME BACK ALL I GET IS THE...
Now tv turn on have the power LED light indication flashes and tv making clicking noises?The tv power supply board is mostly the causes,that the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2011 | Panasonic TH37PX60 37 in. Plasma...
Vizio vp50hdtv20a won't turn on.
The power supply is the culprit.. Check out my video that explains everything..
http://www.youtube.com/watch?v=v_oL1i6VOGM
Jan 05, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
HP-R5052 reboot
It's definitely an overheating problem if your plasma turns off by itself after a while. I would suggest to place a cooling fan near the back of it as a temporary fix.
There could be a power supply issue along with a Ysustainer board but in order to know that for sure, you should use a hair drier and blow hot air to the power supply and see if the TV turns off, if the time that the tv turns off is shorter when blowing hot air to the power supply; then is the power supply issue.
Good Luck.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Phillips Plasma 42" TV
It is most likely a power supply failure and if there had been no signs of problems in the video display, it is probably the main power supply rather than one dedicated to the plasma display itself.
You might leave it unplugged overnight to give any stored charge inside the unit a chance to bleed off, the remove the back panel.
The primary supply is normally on a separate board and is characterized by having mostly larger components, including one or more transformers with black ferrite cores. The main supply will be associated closer to the AC input while the high voltage supply which may or may not be separate is not.
If you can locate the board with some confidence, check it visually for any signs of heat such as discoloration of board or components. If it seems OK it may be a candidate for exchange or repair by Philips.
I wouldn't advise removing and sending it before you talk to Philips to see if this is a familiar problem to them.
Dec 16, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Jan 02, 2008 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Looking for where to find this part
You need to fix power supply module (replace electrolitic capacitor on PCB) in your plasma. It's very frequently failure for this device.
Nov 20, 2007 | Philips E-Box FTR9965 DTV Receiver
Mar 21, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
368 people viewed this question
Computer Repairing
Computer Repairing
