When using my Samsung washing machine model WA11V9,i can't get it to spin dry my clothes fully. It always stopped halfway with a 'UE' sign on the screen. What should i do?
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Sep 11, 2009
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
Apr 09, 2014 | Samsung SW62ASP Top Load Washer
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Stop halfway hygiene wash 90degree
Do you have power to the unit? Does the display light up?
Nov 28, 2012 | Washing Machines
UE displayed samsung washing machine not spinning
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
Oct 15, 2012 | Samsung WF337AA Front Load Washer
What does "ue'"mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung Washing Machines
The machine begins just fine half way through a cycle it stops. Sometimes it runs with no problem. One time we got a code of (UE) I think not sure.
UE = Unbalance Error. For bulky loads, use a lower spin speed. For regular cycles, use a larger amount of clothing per load, and / or a lower spin speed. You can load the drum with dry clothing up to the point where you are just able to reach your arm in to touch the back of the drum. Very small loads can cause more frequent off balance situations.
Mar 15, 2011 | LG WM-2277HW Front Load Washer
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Letters UE on display
Jan 26, 2009 | Washing Machines
My samsung smart wash, when it gets to the spin cycle nearly always comes up with error code UE which I know means uneven, I try to rearrange any laundrey or remove some clothes from the machine but it...
Hi, I have a Samsung smart wash 12455 washing machine and My missus has forced thwe door on our washer and it will not open now. Can you tell me how to get the door open as it is now very loose when pulling on the door open mechanisium..
regards,
Steve.
Apr 09, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
