Question about Russound Ca4 Multiroom Kit
I can't seem to get my russound amp working as the zone 2 of my denon 1713 receiver
I have just purchased both the reciver and the ca4 kit, and the goal was to have the denon reciver run my 5.1 home threater under zone 1, and then have my russound amp connected to zone 2 to run music etc thru the rest of the house. All components are connected to reciver and I also have AirPlay feature on the denon receiver which was what I wanted to use as the main source for the russound zones. I have connected the russound amp to the zone 2 section on reciver using RCAs however I don't get any sound or know which source I should use. Thank you for your help
3 Suggested Answers
SOURCE: I installed a russound CAA66
hi, well this happens because the "Anti-pop" filter either isn't present, usually they are built into the electronics, or it is and isn't active?
But sometimes whatever is used or on we often still have problems, with Pops crackles etc when changing sources or zones etc.
Now, the best way to fix this type of event, is to install things called poly-switches on each and every speaker leg, the devices have NO effect on sound etc, however will NOT allow fast transients to flow into the speakers, they also as an added benefit protect the speakers too.
Some people only put a pollyswitch at each output leg, at the amplifier, and NOT at each leg at the speaker, either way is just as effective. it just works.
www.jaycar.com.au/images_uploaded/polymovs.pdf
Info on polyswitches, above.
Posted on Mar 24, 2011
  • 1212 Answers
SOURCE: Russound CA6.4i zones failing
They should be. I would replace the electrolytics for each of the failed zones. If you do not have a tester, just replace the electrolytics out of hand. The intermittent sound suggests one is likely shorted but not completely or has opened up internally- but not completely.
Posted on Sep 27, 2012
Russound ca4-kt1 no sound
Does the system have its own speakers? I understood that sound system required speakers to be attached. Check that you put the right model up.
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Mar 31, 2014 | Audio Players & Recorders
Unlock denon DBT1713UD
I bought a DENON DBT-1713 UD Zone 1 for DVD and A for BR. Someone knows how to unblock this device?
Jun 26, 2013 | Audio Players & Recorders
No sound from Russound ss-4 after connecting to BACK surround speaker connections on the 2807.
Check the speaker setup configuration in the setup menu. Many times the surround back speaker terminals can be assigned to something else like zone 2. They may just be turned off.
Dec 27, 2012 | Denon AVR-2807 Receiver
Pandora radio stopped working on my denon 1713
direct from Denons website "
Why can't I access Pandora on my Denon networked product?
Please be advised that Pandora has recently altered certain connection requirements which have temporarily blocked our products from connecting to the Pandora service. Our Engineering Dept. is currently working hard to correct this and will have a firmware update available as soon as possible via the internet to resolve this issue. This should not affect your product's ability to receive other music streaming services. Please visit our website for firmware update schedule information after December 6th.
We sincerely apologize for any inconvenience that Pandora's alteration has caused.
Nov 30, 2012 | Denon Audio Players & Recorders
Sep 21, 2012 | Russound Audio Players & Recorders
Hi, I have a Denon AVR-1709 & recently set up Zone 2 to operate my outdoor speakers via AMP Assign. The system is working but I''m only getting limited volume through the outdoor spears and the...
zone 2 volume can be adjusted by zone2 remote control (small one which came with the unit) or by main remote control if you switch it to zone2 mode. My main rem control has a slide switch i have to put in zone 2 position to operate zone 2 amp.
Sep 03, 2011 | Denon AVR-1905 Receiver
I had the unit set to a second zone that ran into a splitter for four different areas of my house. The second zone is not working, how do I test to see if it is the denon unit or the splitter ?
Plug something other than Zone 2 into the splitter, say, any tape out on the Denon. Keep it simple. Play FM.
When and if THAT works go back to the manual and analyze why Zone 2 isn't working. Observe the Zone 2 Output indicator. (Page 5)
You must have a TV or other speaker-capable device that you can run Zone 2 OUT to. Try that to prove your setup works.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-789-Receivers-manual/id/23110dj895/t/2/
Page 17, 30, 31, 57,65- 68 (you get the idea).
Jun 20, 2011 | Denon AVR-789 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Russound Ca4 Multiroom Kit Logo
49 people viewed this question
Top Russound Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
Gil Shultz
Are you a Russound Audio Player and Recorder Expert? Answer questions, earn points and help others
