Question about Garden
Electric chainsaw cs100 mastercraft class 2c serial# t86390 broke
Need a drive gear for the chain approx 3" round cup lots of teeth all gone should have made it out of allum.not plastic or nylon how do I get a new one
5 Suggested Answers
  • 76 Answers
SOURCE: How can I tighten the chain?
follow the instructions in page
http://dl.owneriq.net/3/3e27ad0c-5197-db54-5166-57176dec8be2.pdf
Posted on Jul 15, 2009
VtToolMan
  • 704 Answers
SOURCE: I have a 6 month old remington 16
Try Master Distributors, they have them in stock for under $10 (plus shipping).
Here's a link to the part you're looking for.
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=107713-01
You can also give them a call and provide them with your model number of your chainsaw. Your sprocket number is #107713-01
Hope this helps you get cutting again! Best regards!
Posted on Jul 31, 2009
dontbother10
  • 2220 Answers
SOURCE: I need to find the nylon gear that is fused to the
An IPL for a Poulan 1625 (type 1) can be found here:
http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-1/75.1625-Electric-Saw-Type-1.1.59.1.html
Click the green "Go" tab; Expand the "Illustrated Parts Lists";Click the "Chain Saw Assembly Type 1".
I think you want item 7 ($10.32 & shipping). The nut probably has a left handed thread (tighten it to loosen it). Please let us know if this helped.
Lou
Posted on Sep 14, 2009
  • 1116 Answers
SOURCE: Where can I find a free Remington manual for an
You can find all manuals for Remington Chainsaws at the link below:
http://www.remingtonchainsaw.com/manuals.html
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on May 30, 2011
What size chain do I need
You have the information you need. The chain you need should have 56 cutting teeth and be 3/8ths pitch to ensure it fits the drive on the chainsaw and the wheel at the end of the bar. All you have to choose is the type of profile on the cutting teeth. In the UK we have a choice of Chisel or semi Chisel which mean the following. The Chisel has a flat top and sharp angle down to the chain link and although very efficient at cutting only tends to be used by professionals. The semi Chisel has the corner of the tooth rounded between the flat top and the link. This reduces the amount of kick back (but does not eliminate it). It also reduces the vibration a little when cutting. From the number of teeth it sounds like you probably have a 14 or 15 inch bar. If in doubt measure the length from the body of the saw to the end of the bar. Many on line suppliers will be able to sell you a chain but I would recommend you go to a chainsaw supplier the first time to ensure you get exactly what you need then you can order online for your second and subsequent chains.
Feb 17, 2015 | Garden
My chainsaw runs great sounds great but it doesn't run the chain i have no idea how to fix it please help.
Assuming you have dis-engaged the chain brake then the chain drive behind the clutch, chain drive teeth (below the cutter teeth, and the chain bar end teeth all have to work together. If, say, the chain has a pitch of .325 but the bar and / or drive are 3/8th then the chain won't work. With the little knowledge you have I suggest you take the saw to a dealer.
Jan 17, 2015 | McCulloch Garden
Need to change chain on a Mastercraft MC4000 61DL
I think you could take your chain to a shop that repairs chainsaws and they should be able to get you what you need.
Jun 25, 2013 | Garden
Chain stops when offered to the wood to cut
either a bad clutch or a bad gear in the drive head
Aug 19, 2012 | Bosch AKE 35 SDS Electric Chainsaw
Motor runs but chain is static can get it to go if I pull the chain round by hand but any resistance and the problem returns
Clutch slipping due to wear, or the sproket teeth have worn to the point that it is slipping in the drive links of the chain, i have seen the teeth/spline on the sprocket drum become unbonded, so the drum tuns but the teeth/rim does not.
Oct 10, 2011 | Garden
Have a problem with my electrical Kraftsman chain saw, the engine is running and the chain is rotating, but when I put it against the tree for cut, the chain will stop rotate bot the engine is still...
The main drive gear is slipping. This is caused by etiher worn teeth or worn bearings. If you pass the model number I can show you a diagram of where to look and what part or parts that have most likely failed. The drive gear is the weakest link but the motor can be shifting in the housing away from the drive gear. It only takes a bit less than 1/8 inch side play. The model number will be similar to this 358.341160
Most likely it is item 26 of this diagram:
http://c.searspartsdirect.com/lis_png/PLDM/P0101241-00001.png
This example is for model 358.381160
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Chainsaw-Parts/Model-358341160/0247/1503210/P0101241/00001?blt=06&prst=&shdMod=
Thanks for choosing FixYa, Kelly
Sep 13, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Internal gear slipping ,seems like rart of gear
you may be able to fix your problem by tightening up the chain a bit more. other wise, you may have to have that gear replaced because as you indicate it may have had it's teeth worn down. i would begin by tightening the chain.
Aug 14, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Black&decker ccs818 chainsaw
Each type of chain may be a little different but for the most part it's about 45 degrees for the teeth that have a square outside to topside angle and 35 to 40 for the rounded outside to topside teeth.
Apr 12, 2009 | Black & Decker CCS818 Chain Saw
Ryobi 14 inch electric chainsaw won't cut with new chain
Hi Rossmac,
Both the smoke and it's lack of cutting ability are symptoms of the same problem. The Chain is dulled. Instead of cutting, it's just rubbing on the wood and heating up. It's also not a big deal to fix..
Your options are:
  • Replace the Chain
  • Have the Chain sharpened
  • Sharpen it yourself
To sharpen it yourself, you will need a narrow round file that will fit inside the Chain teeth. Each tooth has a two cutting edges, get the file a position that matches the tooths angle of attack. Don't over do, three to five swipes of the file should do it on each surface.
You will see they alternate directions. You may find it easier to do all the teeth in one direction (skipping every other tooth) then do the other direction. Up to you.
When you are done, check the level of your chain oil. Since it did get hot, you might manually oil the chain before trying out your handi-work.
Go cut some wood.
Mike
Dec 21, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
