Question about Denon AVR-1602 Receiver
Denon AVR-1602 Overheated!
Hello, My Denon AVR-1602 Reciever was powered on high volume about 4-5 hours and it get burning HOT! In one moment it just power-off. I waited to cool down and turned back the power, but the display did not lid. The service diod flshes 4-5 times and then lid constantly, but the display did not lid. There is no sound too. I reset the main cpu by holding Speakers A and B button and power it on but still nothing, then i removed all plugs including the speaker's too but nothing. I opened it up and look around but i did not noticed any visible damage. When it overheated there was no smell of burning element or plastic or else it was just HOT! Do you have any suggestion? Thank you!
  • bor vass May 18, 2007
    Ok, i bring it to a specialist and he told me that the power supply is gone :(. Does anyone know how much cost the PS for this reciver?
I have exactly the same problem. I have checked and replaced these resistors but they didn't fix the problem nor were the old ones open circuited anyway, but I have kept with the new ones for now. I have also checked some of the transistors on the larger heat sink and the power regulator transistors on the two small heat sinks, no problem there either.
I guess the next step is the check the power supply and power relay after that I stumped.
Anyone else got anymore ideas?
Posted on Sep 12, 2012
    Scholar:
  • 54 Answers
Hold on......there are 4 small resistors in the power supply that open up ( no longer work ). This is a VERY COMMON PROBLEM for 01-02-03 model Denons. They are "flameproof" resistors, so when they burn open, there is no trace of a problem, they look normal. This pic is from a 1601 which is almost identical. The resistors are missing from the picture, but you can see where it is marked R 141, R142, R143, R 148.
If your shop measures across these resistors and they are more than 10 ohms, then they are blown, and this is your problem. These should each be replaced with a 1 ohm 1/2 watt Metal Film Flameproof resistor. You must also remember that the little 1602 is NOT a professional unit, designed to be cranked for hours on end. It is a home theatre receiver.
If this solves your problem, be happy and dont beat your receiver to death. .....THIS BEING SAID.....the other reason that these blow is because one or more channels are blown and drawing too much current from the power supply. IF that is the case, be prepared for a big bill. DO NOT try and fix this yourself, as the entire receiver must be taken apart , right down to the bare chassis to get this board out. Leave it for a professional. Have them check the resistors first, it only takes about 10 minutes to get the cover off, check the resistors and put the cover back on........hope this helps... Rob
Posted on Mar 13, 2008
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
lets see, 3100 has no digital out, so you need analog inputs for the audio. Best picture with the 3100, use S-video. Digital input for the DVD sound and S-video in for picture. OOPS....does your TV have a S-Video input ?. If not then you have to use the RCA standard video type connector, as this particular denon doesnt do up or down conversion to or from S-video to old style RCA.
Sorry for the late response.....Rob
PS.....the HD bell wont do you any good with this receiver nbecause it doesnt have component video inputs. Enjoy Bells' superior picture with regular TV . Its way better than cable. Rob
Feb 03, 2008 | Denon AVR-1602 Receiver
Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Jul 22, 2007 | Denon AVR-2802
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
Denon AVR-1602 Receiver Logo
948 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
