Question about Teac Audio Players & Recorders
Teac hdb850 receiver sound cut out and isn't coming back
No sound when going through receiver. tried normal t.v. there is sound. no mute buttons on.
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Pioneer receiver is
Look on the remote. Near the bottom.
Posted on Apr 06, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have no sound coming out of receiver all of a
It is an indication that you have a faulty output ic.
Output ic is responsible for amplifying the audio from your reciever to sound output which is converted by your speakers.
If you're output ic is defective then definitely you haven't sound produce even your unit is working.
I've advice you to look for a qualified technician to checked the condition of your output ic and do some re-soldering for some dry joints on the board.
Thanks for using fixya...
Posted on Jan 09, 2011
dunnbiker
  • 8546 Answers
SOURCE: TEAC AG-V1200 receiver won't auto turn on when
No. It won't automatically turn on when power is present.
Posted on Aug 08, 2011
dunnbiker
  • 8546 Answers
SOURCE: Receiver comes on but have no sound tried the
Mute Auto is for FM only. It mutes interstation hiss while tuning. Look for some other indicator that might reveal why the signal path is failing. Tape?
Have you tried the basics? Speaker test? FM only?
Posted on Sep 02, 2011
What is the code for a teac set top box model hdb850
Codes are in the remote. If you are using a TEAC remote with a TEAC STB, you may be able to find something that will work.
Jul 16, 2016 | Teac Televison & Video
My t v has no volume
Do you see the volume indicator moving when you press the vol up/down?
Could the internal TV speakers have been turned off? This is done when using a sound bar or a AVR (Audio Video Receiver) aka Home theater
Mar 03, 2015 | Televison & Video
Why dont i have sound
First , make sure the speaker switch is ON
Second , make sure no TAPE MONITOR function is on.
3rd, Make sure ( if there is a Mute switch) , turn that off.
If still nothing, try headphones and see if something comes through
Feb 27, 2015 | Teac AG-V8060 Receiver
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
I have a Teac Receiver AG-D9100, sound cuts off, but if I touch the master volume knob it comes on for a short time. What to do? jmf
This can be related to a fault in the potentiometer as it cut off the tracking of the voltage and gets back to feed the digital circuit. You need to check, sometimes a switch cleaning oil can help.
Try to wriggle the pot control many times as it can help, if not replace.
Oct 07, 2011 | Teac AG-D9100 Receiver
I can't get sound out of my amplifier and I haven't changed anything. What could be the problem?
Start by choosing FM on a known frequency with a station broadcasting and volume is turned down to a NORMAL listening level. Next, make sure speaker selector isn't the wrong position (make sure "SPEAKERS OFF/A/B/A+B is set to A [or B to match the speaker terminal connections]), check to be sure "Mute" function is not activated by pressing the MUTE button on the remote to toggle it between on & off, Make sure headphones are disconnected. Make sure "PROTECT" is not displayed on the front as this indicates a shorted speaker wire - shut off and repair the shorted wire(s).
If you get sound on FM, but have an issue with another external component (CD, DVD, Phono, etc.) check the cables between the component and the input panel on the rear of the STR-DE595.
I hope this helps & good luck!
Sep 13, 2011 | Sony STR-DE595 5-Channel Amplifier
We dont have the manual for our TEAK AGV 1200 RECEIVER AND I NEED TO KNOW HOW MANY WATTS IT HAS? Any way I can find out with the manual?
You have to type alpha-numeric gibberish verbatim or there will be no good information coming back.
If you mean TEAC AG-V1200 then just google it.
Here's a manual for $10 http://www.teac.owner-manuals.com/AGV1200-owners-manual-TEAC.html
It probably has the specs.
This seller claims 110 watts per channel all around, which sounds supsiciously generous. Rear channels don't need that kind of horsepower.
http://cgi.ebay.com/Teac-AG-V1200-Dolby-Surround-Receiver-Remote-/250828929416
Aug 04, 2011 | Teac AG-780 2 Channels Receiver
Teac AG-V8060 Receiver No sound. If I turn up the volume all the way I get a whisper of sound from the speakers.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Jun 04, 2011 | Teac AG-V8060 Receiver
No sound, neither speakers nor headphone jack
Here are a few things to check and try, as suggested from TEAC:
  1. First, make sure the Tape monitor or adapter switch(s) are not accidentally left on.
  2. Check that the speakers and components are connected
    securely.
  3. Adjust the volume by turning the VOLUME knob.
  4. Check the operation of the connected component.
  5. Select the proper source using the SOURCE button.
  6. Pull out the headphones plug from PHONES jack.
  7. Speaker impedance may be less than prescribed for this unit.
  8. Turn the power off and reduce the volume.
  9. If muting is on, press the MUTING button.
  10. Another solution for you would be to take it to a service shop for a repair cost estimate.
Feb 23, 2011 | Teac Audio Players & Recorders
Teac AG V7700 Receiver problem powering up
I have a Teac ag-7700 and when I would try to power it on it would shut off. I did get it to turn on for about 10 minutes and then it shut off. Now when I try to power it on the light on volume dial stays lit but the LED does not light up and no sound through speakers.
Jul 30, 2008 | Teac AG-D8900 Receiver
62 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
