Question about HP DeskJet F380 All-In-One Printer
F380 not printing on mac reason: hp aio print2 pde plug-in
For some reason everytime i click on print the document im printing suddenly quits. Reason given is hp_aio_print2_plug-in.
im using mac. what do i do?  need help asap pls!
  • 3 more comments
  • Anonymous Jan 19, 2009
    Exact same thing happens so me
  • Anonymous Jan 28, 2009
    same
  • Anonymous Jan 29, 2009
    tidak bisa ngeprin juga
  • Anonymous Mar 13, 2009
    Same
  • Anonymous May 05, 2009
    will not print or scan from my mac
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
HP DESKJET F380 ALL IN ONE PRINTING IN RED
Hi Jasmine
I am attaching 2 documents, please try the steps in the document, i think either the tri color cartridge is out of ink or it might be an issue with the tri color cartridge
try this document first : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01423255&cc=us&lc=en&dlc=en&product=3390947
If No go then try this document : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01429694&cc=us&lc=en&dlc=en&product=3390947
Please respond back so that I can help you.
Regards
Santhosh
Jan 26, 2009 | HP DeskJet F380 All-In-One Printer
F380 All-in-one Deskjet
What sort of document are you trying to print (Word document, Excel spreadsheet, something else)? Also, what kind of paper are you using? Certain types of paper can stop progressing through the printer for a variety of reasons, regardless of the document type.
Thanks.
Sep 25, 2008 | HP DeskJet F380 All-In-One Printer
Mac not printing to HP Deskjet F2200 series
1) First let's make sure the hardware is working. Place a document face down on the scanner glass. Press Start Copy Black. Did it scan and print?
If not, please let us know.
If it did, go to the next step.
2) Please confirm the USB cable is plugged firmly into the back of the printer and to the computer. Do not go through a hub, switch, or router.
3) Click on your Apple icon (upper left corner), System Preferences, Print and fax.
Do you have the F2210 printer listed more than once?
I am going to suggest removing the F series printer. Highlight it and press the minus button to delete. Once you have removed it, close all windows back to the desktop.
On the computer click on Hard Drive > Applications > Hewlett-Packard > Device Utilities > HP Setup Assistant. Follow the on screen directions to add the printer back to computer. Do not re-register the printer (choose skip or register later). Once your are able to click finish, try printing again.
I would suggest trying to print from Text Edit first. This will rule out any possible issues with the Word document you were trying to print. Click on Hard Drive > Applications > Text Edit. Type your name in the untitled screen. Click on File > Print. Make sure the F2200 series printer is selected. Click Print. Did it print?
Sep 24, 2008 | HP DeskJet F380 All-In-One Printer
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
How do i get an hp laserjet 4550n duplex to work ?
duplex printing in your model is optional im afraid
for the ff model pls see:
HP 4550 / 45500N: Optional
HP 4550DN / 4550HDN: Yes
unless otherwise that you have the duplexer installed and the selection from your properties selected like what you said, then there is no reason why this would not print back to back
keep inspecting your unit pls
cheers
Aug 28, 2008 | HP Office Equipment & Supplies
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
Nov 21, 2007 | HP DeskJet F380 All-In-One Printer
Printing suddenly slows down for no apparent reason
This is more likely a computer issue than a printer issue. The only way to prove it is essentially try the printer on another computer. Preferably one with more RAM and faster CPU.
You could try closing some of the running processes via the Task Manager. This would free up some resources and may help the process.
Oct 17, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
432 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
