Question about Dell E173FP 17" LCD Monitor
I have a Dell E173FP LCD monitor and everytime I try to access the OSD menu a lock appears on the screen. What is the solution to this problem?
  • Anonymous Apr 10, 2009
    i have a e173fp can you stop this explain step by step
Thanx for your help. That should work too, but I tried pressing the menu for 15 seconds and it unlocked.
Thanx again
Posted on Jan 06, 2009
I have the same problem. I have spent alot of time diagnosing it. It is the button assembly malfunctioning.. The button assembly needs to be replaced but I have looked everywhere for a replacement part but none cane be found because none are sold. It sucks. If you take the case off you can see and remove the button assembly fairly easily. I think if your are good at soldering, the best thing (and only thing you can do) is to purchase individual replacement buttons, remove the old buttons and solder new ones onto the board. I am really bad at soldering so i will never do it. I hope this helps.
Posted on Oct 04, 2009
  • Dell Master
  • 1,183 Answers
In the on screen menu , the OSD lock is selected , Try factory resetting the monitor, the problem should go away .
You can also refer to the link below , browse to the section "OSD settings "
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
Thanks
proton
Posted on Jan 03, 2009
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Cn-ou4931-46633-52L-OHGU - monitor keeps showing
Here you go!
From Dell website:
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds. See more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 13, 2010 | Dell E173FP 17" LCD Monitor
A lock turns up in the middle of the screen
You have inadvertently locked the On Screen Display (OSD).
To unlock do the following:
Press the menu button, which will take you directly to the OSD settings menu, and you will see 'OSD Lock' is selected. Change the seeting to No(-) to unlock and allow user access to all applicable settings.
Mar 07, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
A lock symbol appears
Hello. On this Dell flat panel the menu access appears to be locked, if the lock symbol you are referring to is from the monitor itself.
You should be able to lock or unlock the OSD by pushing and holding the Menu button for 15 seconds.
Oct 23, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Osd lock problem
Hi
Try this.
PRESS AND HOLD THE SOURCE BUTTON FOR 20 SECONDS.
Should now be fine.
http://dc07.atspace.com/
Chris..
Dec 15, 2007 | Gateway FPD2275W LCD Monitor
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
E173FP flat monitor
Try pressing and holding the menu button for 15 seconds! That should unlock the controls! Regards, babb
May 08, 2007 | Dell E173FP 17" LCD Monitor
Padlock appears on screen
Hold the menu button until the padlock unlocks, it takes anywhere from 30 seconds or even a minute or so
Mar 12, 2007 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
664 people viewed this question
Alun Cox
