Question about Sharp UX 355L Plain Paper Thermal transfer Fax
2 issues, can't enter my fax #, Major black lines and poor image on copy. I just got this from a thrift store still in new packing and wrapped up, never touched or used.
I have everything. This was in the box, in the Styrofoam, each part in it's original wrapping untouched. I have used the manual to set up the fax, but according to the book I should get a "Own Number Set" display after a sequence of "function", 3,#, #. Instead I get "Security select" and punching additional # through the entry mode does not show the own number set. Believe me, I have gone through every setting I can find, but it isn't there. Could VOIP be an issue here? The second problem is when I copy it is horrible quality. Large vertical black bands and lines across the copy and the image is broken with washed out vertical lines. I haven't tried to send a fax yet as I'm afraid the scanning is messed up. When I do a machine print (report) the image is crisp, clear, and fine. I suspect the scanning part is messed up somehow, but everything is pristine new. Any ideas or experiences? I'm speculation DOA from sitting.
  • Alan Jorgensen Oct 29, 2012
    Thank you both for your comments. There is no cartridge as it uses imaging film I could change, but it prints clean reports with nary a streak. Just streaked copies. I appreciate the link for parts, but I'm taking it back to the thrift store. I paid $30 for it and they're around $60 new. A real shame, DOA out of the box.
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
Black line on scanned copy
If you notice poor image quality in scans, faxes, or copies, you may need to clean the scan lens and the white roller.
  1. Unplug the power cord from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One. Note: The scan lens is located under the white roller.
  4. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  5. Reinstall the white roller.
Jul 26, 2011 | Lexmark X4270 All-in-One Multifunction...
I have a brother 770 fax. When making copies or sending faxes the paper has long black narrow lines running from the top to bottom. Please help.
Hi There!
One reason why you're having a black line on the copies you make and faxes that you send it's because the scanner glass inside the fax machine is dirty. Here's what you can do to resolve you're issue.
-Make sure the printer is off and unplugged from the power outlet for your safety. -Open the control panel, Prepare a dry lint free cloth and isopropyl alcohol, dampen the cloth with a small amount of alcohol. -Inside the fax machine look for a the long scanner glass clean it with the dampened cloth, using hand try to feel if there are debris or dirt and concentrate on cleaning that part. -Directly above the glass you will see a white strip clean that also with the dampened cloth
Once you're done cleaning, close the cover and plug it back in. Try to copy a blank sheet of paper and if you can still see the same line clean it again for about 3-5 times, Make sure to make a copy everytime you clean the glass.
Hope this helps!
May 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Trying to send a fax error: Poor line condition/ Out of memory
Make sure by making a copy that your scanner is OK, streaks or black bands won't send properly and you need a new scan assembly, Poor line condition is just that, you need a better line or cable, If you go to fax settings and turn off error correction mode it sometimes helps as well.
Feb 01, 2010 | Brother MFC-8460N All-In-One Printer
The outgoing faxes are becoming unreadable, any idea as to why this is occuring and what we can do to fix it?
I will look it up in the morning, I don't have that information with me at the moment, But there is a scanner calibration you can do to correct it.
You have to enter some codes and simply run white paper through the scanner to reset the values. But off hand I can't remember the exact numbers. I will get look them up and send it on here.
It is not hard to do at all. Will take about 2 or 3 minutes.
Jan 11, 2010 | Xerox FaxCentre F116 Plain Paper Laser
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
POOR COPY QUALITY
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Office Equipment & Supplies
Poor Quality
If you can copy ok you have effectively ruled out your machine as you have used both the scanning and printing mechanism of the machine.
It will probably be the fax on the other end as if it sends a poor quality page that's all your machine can receive, a poor line can also cause problems if it is from multiple faxes. If so have your provider check the line (you probably hear static on the line).
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Sharp UX 355L Plain Paper Thermal transfer Fax Logo
46 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
