Question about Vacuums
Sabco mop with telescoping handle: handle is jammed
This mop has a telescoping handle in two parts. To adjust, you turn the collar between the two parts in one direction, extend or shorten, then turn the collar in the other direction to tighten. The handle on my new mop has jammed in the extended position and the collar won't budge at all. I suspect the two parts of the handle may have been jammed together while the collar was in the locked position, because when you're attaching the fabric pad to the mop you have to push down on the mop head with the handle in order to lock it flat again. Any suggestions for unjamming one of these collar-style telescoping handles?
kevin000
  • 1847 Answers
SOURCE: Attachment of vacuum base to handle
yes friction and the air suction presure keep the head and the handle together.
Posted on Jul 25, 2008
SOURCE: electrolux oxygen plus 2100w telescopic
I have a electrolux 2000 and my tube has a small tab that you push before it would let me release it. I had trouble getting it off as well. What I did was push the tab, Plasing one foot on the vaccume head holding it down while pulling up and twisting. I'm not sure if yours is attached the same way but this method worked for me. Good luck!
Posted on Aug 18, 2008
FitzOriginal
  • 842 Answers
SOURCE: handle is loose and won't snap down and lock into position
This is usually caused by a build up of dust in the flexible pipe. It stops the pipe from compressing down and so you cant push the handle down far enough to get the latch to click home.
Try stretching the hose to its fullest extent and while someone has ut stretched, give the lengthe of the hose a good beating to knock the drit in it loose. Alternatively, if you can remove the hose, fill it (and boy will it expand and slosh about!) with a mixture of hot water and floor cleaner (I use flash) Slosh it about intil the hose is full of gunk, then pour it away. Then, put the hose in your airing cupboard (Stretched out!) overnight to dry. When you put it back together it should now compress enough for the latch to clich home.
Posted on Mar 01, 2009
SOURCE: Shark steam mop won't steam
I have had my steam mop for about 2 yrs and absolutely love it. I have not experienced any difficulty with it until I recently noticed it would heat up but not steam.
I contacted Shark's Consumer Products services at 1-800-798-7398 and the person on the other end was very helpful. After giving me a few pointers, we discovered that my mop needs repairs.
They have a one year warranty, which my mop is past, so I will need to mail it in to them with a check for $9.95 for return shipping and a check for $17.95 for repairs. They will replace it if they are not able to repair it for no further costs.
I highly recommend giving them a call. There is also a live chat available on their website that can point you to the service or person you need to speak with.
Posted on Aug 06, 2010
heatman101
  • 43501 Answers
SOURCE: My Shark is less then
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
rf
Posted on Sep 24, 2010
Low power from steam mop
Try to be a little more vague! Model? Age of steamer? Rate of use?...Try a couple of drops of vinegar in with the water you use to fill your steam mop. The heating element that heats the water is probably oxidized, especially if you use tap water to fill it. You should only use distilled water in these mops. Some lower end steam mops have a handle that compresses, as you push the mop forward, which essentially makes the mop steam more, the more you "pump" the handle. Hope this helps!
Jan 29, 2015 | Vacuums
Shark s3601a no steam
Don't you have to push down on the handle while mopping the floor to get the steam to release. I know the one I have has a handle that slides down the shaft in forward mopping motion which releases the steam.
Oct 15, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My Euro-Pro Shark mop head is stuck in the base and the button will not release it.. I tried everything. I have unplugged and let it cool now not sure what I can do.. so frustrated
Same exact problem I am dealing with. My mop also got jammed about the same time. I have called the 800 # and they told me to send them the MOP and all the parts with a check for $27 ($10 is for return shipment). I'm not convinced they will be able to fix it.
Jan 09, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop handle broke, is there anyone who sells the replacement parts for these?
i know of a great site that sells all kinds of shark parts check it out
http://stores.ilikenew.com/-strse-Replacement-Parts/Categories.bok
Nov 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The plastic housing the handle locks into has cracked. The handle comes out when pulled back with little force.
Sorry but there a very few parts for these...
heatman101
Aug 25, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The handle of my Shark Steam Pocket Mop Cleaner
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
May 07, 2010 | Euro-Pro Ultra Steam SharkTM II Hard...
I broke the handle on the S3101 Shark Steme mop. How can I get parts?
Check the link for manuals...
heatman101
Apr 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Engonmic hand grip broke off
Check the manuals link and maybe they will replace it under warranty...
heatman101
Aug 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Jan 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
189 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
