Question about Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000
Cant get my power ate 8750 to start. Ran fine last year. Have changed spark plug, aded fuel stabilizer, will starting ether help?
    New Friend:
My son in law drained the carborator 3 times to get the old gas out. Also put in an additive to the gas. He figured our unit had sat too long and the gas was getting old. It is running fine now. Just need to figure out how to idle it down.
Posted on Jan 27, 2013
4 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: My Coleman Powermate 7000 won't
I not you said you "checked the oil level" My experience with most portable generators is that they must me positioned as level as possible and the oil level must be fully serviced as full as you can get it without oil leaking back out of the dip-stick hole on units WITHOUT an extended dip-stick. Unless those conditions are met the low oil level sensor ends up presenting a false low oil signal and it grounds out the ignition. DO you have Spark at all? If you do have spark and it still does not run respond with the MODEL number off of your ENGINE and I will show you where the main fuel jets are located so you can make sure the orifice is clean.
Some units have a fuel solenoid that presses into the main fuel jet recessed area and shut off the fuel to the carb. This is also an area that debris causes havoc.
Thanks,
Kelly
Posted on Aug 29, 2011
SOURCE: Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Posted on May 18, 2010
  • 54 Answers
SOURCE: it's 4 yrs old but
After four years the magneto will become demagnetized. Get a small magnet and find the spot on the flywheel where there is some steel which will be slightly magnetic. You can just stick it on there for four days or work it and tap it lightly on the steel for many minutes. Two hours should be enough to get it started and from there it becomes very strong as it revolves past the magneto's steel core. They use to use Strontium alloy to make it keep it's magnetism but they are cheaping out on all steel alloys now. When you can get it to draw in a steel bolt or some other ferrous item so it goes clack against the flywheel, then you have it ready to fire. If it has a compression release, make sure that is all the way over to start, then when it fires bring it back towards you to get full power. I left mine without gas in stroreage for two years and it just barely started. I pushed the plug-in GFCI center buttons a few times and it came to life.
Posted on Apr 10, 2011
My snowblower starts then stalls
Rob; 95% sure it is a carburetor issue, dirt clogging a port or jet,float sticking. I will post a few sights below to show how to clean carb.
How to Fix Snow Blower Carburetor
HOW TO Clean Rebuild Tecumseh Snowblower Carburetor PART 2 OF 4
how to rebuild snowblower carburetor
Jan 30, 2016 | Cars & Trucks
Having trouble getting my BlackMax 7000 watt trifuel generator started on Propane.
Clean off the fuel connect points. Probably just not a clean line from sitting so long since last use.
Dec 25, 2014 | Honda Black Max 7000 / 8750 Watt Portable...
Manage my life com sears
-Make sure has fuel. It should start.
Good luck
mai
Jul 09, 2014 | Craftsman 4-Cycle Mini Tiller
Ice auger isn't getting gas....
You will probably have to remove and disassemble the carburetor. Clean thoroughly and reassemble. Drain the gas line until fresh fuel comes out. Always run premium nonoxygenated( no ethanol ) fuel in your auger and add a fuel stabilizer like stabil or seafoam .this will help keep the problem from reoccurring. Hope this helps.
Jan 12, 2014 | Motorcycles
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Two years ago i purchased a Craftsman riding mower with a Briggs&Stratton 24 hp inteck v-twin, it ran fine the first season but that was it. Last year i tried to get it started by changing plugs and...
Gas is so poorly refined these days, Youll notice the fuel stabilizer says it is only good for about 30 days. although i cant give specific instructions on how to clean out the clogged jet in your carb, if it runs on starting fluid, a clogged jet is deffinately your problem. start with the float bowl make sure it has clean fuel in it and the primary jet is usually in the bolt that holds the bowl on make sure its clean and if the float hanging down opens the needle valve and fuel flows your good to that point. if the engine still wont run, or only runs with the choke on. get some carb cleaner spray and go at it, make sure you can blow through every port and jet, BUT WATCH YOUR EYES you never know where that stuff is going to exit.
next year winterize it, drain the fuel and run it till it dies.
or i like to winterize my engines by replacing the regular fuel with a little bit of aviation fuel as that stuff can sit for years, just dont operate or mow for more than 2 or 3 minutes on it.
Good luck
Apr 22, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM0497000 Logo
234 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
