Question about SanDisk Sansa e200 MP3 Player
Sansa screen ok i'll plug mine sansa in it will connect to 75 songs which i have alot more. then when i unplug it a blue/white screen comes up and moves. then it wont do anything till it dies. and it just started happening what do i do??
Can unscrew the back, and remove the battery. It should reset the player.
Posted on May 21, 2007
I just plugged in my sansa m230 and loaded some songs on it. After I was done, I unplugged it and the screen keeps flashing back and forth from "initializing" to a screen that says " Sansa m230 512 MB". I...
ok, hold the power button for 20 seconds or more. it should do a power emergency shut off. wait ten seconds and then turn it back on. BAM! it should be good.
Sep 29, 2010 | SanDisk Sansa m230 MP3 Player
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e250R is frozen, and no solutions work
I had this problem once. I unscrewed the back with an eye glasses screwdriver, took out the battery and replaced it and that took care of it.
Aug 08, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Connection screen
Reset the player - manual has instructions
Remote possibility:
Use the Thumbwheel to rate the song (1 to 5 stars) then press
|<< button to return to Music Options menu. My Top Rated
Songs can be viewed in MUSIC menu.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e280 malfunction
i have solved my problem !!
if it says connected and when you plug it and out and it is still not working you just plug then unplug (might take some time)
Nov 18, 2007 | Audio Players & Recorders
Sandisk Sansa e250 problems
chagne the mode of the player to MSC and format the player using your computer. The sansa connect recovery is used for a different device.
Aug 22, 2007 | SanDisk Sansa e250 MP3 Player
ok, mine had the same problem, first go to settings, then USB mode and switch it to MSC, plug it into your computer and it should show up, then format it, this will erase everything but then u can put it back on, after you format it you can switch it back to MTP mode, its alot better, hope i helped
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
