Question about Bosch Nexxt 300 Series WFMC2201UC
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
    Top Expert:
  • Bosch Master
  • 9,472 Answers
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Posted on Oct 28, 2012
barkencoa
  • 3463 Answers
SOURCE: washer drum doesn't spin, no draining of liquid
If you have got rid of all the water, and it still will not spin, then the odds are it is the brushes in the motor that need replacing.
Quite a common problem
Posted on Jan 19, 2010
Testimonial: "I will tell repairman from Sears ( coming Friday ). i'll ask him to check brushes before he pulls motor. "
textonor
  • 130 Answers
SOURCE: Clothes too wet upon cycle completion...
Try reducing the amount of low sudsing detergent you are using. This can make the load too heavy and won't spin out. Remember suds have 3 parts, air, detergent, and water. The drain pump is designed for water, so if you see suds during the wash, it will be worst on warm and hot, then there is too much detergent, or is not low sudsing. I know Bosch reccommends HE, however HE liquids normally are not low sudsing, just High Engery. Also the Permanent Press cycles are always a lower spin speed. Hope this helps
Posted on Jan 23, 2008
barkencoa
  • 3463 Answers
SOURCE: Clothes wet....not spinning as fast.
Suggest you check and clean filter, if clear then check brushes in motor.
Please rate my solution.
Thanks.
Posted on Mar 29, 2009
barkencoa
  • 3463 Answers
SOURCE: Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Posted on Dec 25, 2008
localwonder
  • 6784 Answers
SOURCE: clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Posted on Jun 10, 2009
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
All cycles work but clothes come out wet, top loader model# AAV7000AWW is there a lint trap that needs cleaning?
Lint traps are in dryers, not washers If clothes still come out wet then perhaps the water pump is not working properly and/or the drum is not spinning fast enough to allow centrifugal force to remove water from clothes.
Feb 07, 2016 | Washing Machines
When there is a large load of clothes in the washer my washer does not spin fast enough to get the water out of my clothes, what is wrong with my washer?
You don't have to fill too much the washer, leave 1/4 of the cylinder free (if it's a front load washer) or check the maximum level for the top-load washer.
Be careful not to compress the clothes.
The weight that the washer can manage is the weight of the WET clothes.
More technically: the washer need to balance the drum before to spin-dry and for this it needs some free room in the drum. There is a sensor that check that there isn't too much vibrations during the spin-dry, otherwise it stops!
Sep 12, 2013 | Washing Machines
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What will cause the washing machine to not spin fast enough to spin the clothes dry or not spin the fabric softener out of the agitator cup?
If your towels are coming out the dryest it is probably a problem with it being off balance. Did you make sure that the clothes are even placed in the washer. If you have a bunch of heavy stuff on one side and light stuff on the other side it could cause the same problem.
Dec 05, 2012 | Maytag Legacy Series Top Load Washer
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Drum will not spin on any cycle.bosch nexxt 300.
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Washer-Parts/Model-WFMC2201UC13/1794/0153200/50033052/00003?blt=06&prst=&shdMod= If the drum is not turning on any cycle then I would suspect either the belt - Item 308; or the motor - Item 327.
If you are saying that it doesn't go into the spin cycle (but the drum turns in other settings) then I would suspect the control board - Item 333
Jun 24, 2011 | Bosch Nexxt 300 Series WFMC2201UC
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
1,049 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
