Question about Pioneer Vsx 519v-k 5.1 Home Theater 550 Watt Receiver W/ Hdmi
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
It will not recognize the tv, cable receiver or any other component. The hdmi light keeps blinking. It will not allow me to reset it either.
  • Brad Haswell
    Brad Haswell Jan 05, 2014
    You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked! thought I would post the instructions for anyone else that lands here: Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Posted on Jan 05, 2014
  • 6 Answers
SOURCE: I have a motorolla DSR505 sattelite receiver that
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Posted on Dec 07, 2009
dragonsthatk
  • 547 Answers
SOURCE: No HDMI Output thru' receiver
you most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Posted on Feb 12, 2009
MrScary66613
  • 1990 Answers
SOURCE: OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Posted on Jan 02, 2009
smarthome2
  • 1114 Answers
SOURCE: manual for pioneer elite ex 500
I went to Pioneerusa.com then support then home audio video then older models. They list a 49 and a 51. No 50. You can download any manual from their site for free. Is it a USA model? if not, post a comment and I will find the info for you. Hope this helps
Posted on Jun 20, 2009
smarthome2
  • 1114 Answers
SOURCE: Can the Pioneer VSX-74TXVi support 1080p video
No. Your receivers HDMI version is 1.1 It was the first, and as always, riddled with compatability issues. Nothing you have should be run thru this receiver via HDMI, use your receiver for digital audio switching via optical or coaxial digital. If you really want all the HDMI info and problems; google hdmi forums. There are hundreds that specifically deal with this issue and all the specifics you could ever ask for. Long of the short of it though, Version 1.1 will not work and can not be updated by firmware. Also, it's not Pioneer's nor any other MFG's receiver's problem it's 80% recording industry trying to protect copyright on video, and 20% poor design by HDMI and not forward thinking. Hope this eases the frustration!
Posted on Nov 22, 2009
My pioneer 5.1 av receiver is showing hdmi light .i bought a hdmi cable but the light is still on and does not want to play.
You got to go to set up button and change it from anolug to digital for what your listening to,like tv,DVD,etc
Nov 21, 2014 | Pioneer VSX-D510 Receiver
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
No picture through Pioneer VSX 818V. Hi I have connected a blueray th the hdmi input and the tv to the hdmi, I have sound but no picture or on screen display?
Your receiver has 2 HDMI in with one HDMI out, 3 Component in and one out, and two difital optical in. If the bluray player has HDMI out this woukd be your best bet because HDMI carries the audio and video. If it has Component out, you would have to provde sound through the digital optical. Not knowing what blueray player or kind of tv you have, it's hard to advise so I may be over explaining. Anyway, we've touched on the bluray player to receiver. Out of your three HDMI slots on your receiver only one is HDMI out so make sure you're in the right one. Idaelly you have a DVD/blueray in on your receiver so on your receiver you would select "DVD" when playing. If your hook up is correct you may have to try another HDMI cable to test.
Mar 27, 2011 | Pioneer VSX-818V-K Receiver
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
check audio ic & component like resistors & capacitors. good luck!
Apr 26, 2010 | Pioneer VSX-518-K Receiver
Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Pioneer Vsx 519v-k 5.1 Home Theater 550 Watt Receiver W/ Hdmi Logo
3,883 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
