Question about LG Washing Machines
Lg front loader WD801 3F power won't turn on
Model WD801 3F
5 Suggested Answers
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
MNTECH
  • 1543 Answers
SOURCE: Does a pedestal for the
Yes, it can be used, but the fastening system for pedistal to washer is much better with the new pedistals.
Posted on Jan 25, 2011
  • 6277 Answers
SOURCE: Bosch Maxx 900 front loader
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 21, 2011
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
Jan 12, 2013 | LG WT5001CW Washer
My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Nov 28, 2012 | GE Washing Machines
My LG WM2101HW front loader will not spin. It drains OK, but won't spin.
I would be leaning more in the direction of the door lock mechanism rather than the hall sensor as someone else posted. The hall sensor gives a very specific error code when it goes bad. Put the unit into a spin only cycle and verify that the door is locking. To do this power up the machine and only press spin speed and the start. It is also possible that it is a problem with any one of the three control boards that are on the unit but again, these normally present with very specific error codes. If the door is not locking, or even if it is but the switch isn't sending the signal back to the main control saying that it is locked then all it would do is drain and then spin 1/3 turns either way inside the tub until time runs out.
Nov 14, 2012 | LG WM2101HW 4.0 cu.ft. Washer
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Aug 07, 2011 | LG WM3987HW Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
LG RH2T80 HDD/DVD recorder dvd tray won't shut we have turned off the power and at the power point but it still won't shut. It sounds like something is locking or jaming. It goes a 1/3 of the way...
This is a common problem on this model LG RH2Txxx DVD Recorder unit.
Source and install a new DVD player/burner unit - cost approx $120.
Avail from :- http://spares.bigwarehouse.com.au/product_info.php?cPath=24759_24831_81108&products_id=1546447&s=lg%20rh2t250&n=1&pcid=2274323
Easy to self instal with basic repair knowledge (+ philips screwdriver).
Remove top cover screws and cover,
Unclip front plastic front cover, roll out of way,
Remove 4 mount screws of DVD player/burner unit,
Unplug ribbon cable and DC power connection to DVD unit.
Install new unit by reverse of above procedure.
Jun 04, 2011 | LG DR787T DVD Recorder
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
