Question about Canon I990 InkJet Photo Printer
Canon ip1880 color cartridge cannot detect & extra ink still ful
I bought ip1880 that had extra ink outside extended to the cartridge. The extra ink not finish yet but the cartridge did not work properly. While to printing my computer always appearance a message - "The following ink has run out and color[831]
Replace the ink Cartridge and close the cover.
If printing is in progress and you want to continue printing, press the printer's RESUME button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition. The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. the resulting print quality is not satisfactory, if printing is continued under the ink out condition." I tried to let the extra ink entrance but the ink can not flow properly and wasted spilled out. I also tried to refill but had same problem. Please i need a help and an idea.
  • Anonymous Mar 31, 2009
    printer canon ip 1880 the following ink may have run out black
Press the resume button for 5 second
Posted on Jan 29, 2009
Hello Arul,..
herewith the simple way..
first download  the reset-er file from here ;
http://www.ziddu.com/download/357557/U_resetter ip1880.rar.html
1. Turn off printer, and than pull out cable power
2. Press hold POWER button
3. Plug in cable power
4. (Still hold power button) press RESUME button 2 times
5. Release POWER button from your finger
6. will reset your Ink Tank Full Error (1st STEP FINISHED)
(power lamp keep blink )
2nd STEP
(Reset Software) for permanent
1. Run the reset-er software, (the active printer type should indicate in top left)
2. reset EE PROM
3. Click Test Pattern 1 for test page
4. Finished, your iP1880 become normal again
this software also suitable for reset your ink indicator after refill.
Disclaimer :  this cheatmight be illegal, so we not responsible if any damage on your printer or device. You have to responsible by yourself with regards to your experiment.
gd luck!
gethoek-kimpoel
I got free before, so you get free also.
Posted on Feb 21, 2009
I have canon ip1880 when i give a print command it shows the message on my monitor ink cartridge cannot recognised - color
Solution: press and hold (10 second) reset button/resume (Button reset/resume, under the power button)
Sep 23, 2011 | Canon Office Equipment & Supplies
Tip
Canon Pixma MX320 - How To Disable Ink Cartridge Error Detection..
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
I have a canon Pixma328 and have been refilling ink for black and color cartridges for quite sometime now. The cartridges are close but after I drilled a small hole on the top part of the cartridge using a small screw, there I find a way to refill the ink that I bought from an ink refill store. The procedure needs extra care, not to touch the contact point (copper) because its sensitive and not to damage the inner part of the cartridge when I insert the needles of the syringe used for transferring ink.
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
You can print as long as you want, refill the ink as long as you want and save a lot of money from buying a genuine canon cartridge by just following this simple tips for Canon Pixma MX320 and/or Canon Pixma MX328 all-in-one printer
For those who have replaced their ink cartridge before try to use that again and do follow this tip to make that work again.
on Jun 29, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon ip1800 printer won't print.
My Canon PIXMA iP1880 cannot print...and shows a message "ink absorber is full" can u help me this problem..
Mar 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink
Better not to refill. Better buy a new original Canon cartridge. The reason being that some of the newer printers have sensors which can detect refilled cartridges and will cause more problems later.
Nov 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
IP1880
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE. Also check to make sure that if you have only one cartridge that you go printer settings/maintenance/ink settings change to cartridge you will be using black or color.
Both of the cartridges have to be in there whether one is empty or not. Then turn off wait a few seconds then turn it back on. This worked for me. I hope is works for you.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Help me pls...
First of all to make your ink last longer you need to be using the Canon PG-40 and CL-41 instead of the Canon PG-30 and CL-31. The 40's are the higher capacity versions of the 30's. If you mean to ask why your color cartridge is going empty when you don't print much color, it is because when you print in black and white your printer mixes in some color with the black. There is no way to stop your printer from mixing color ink with the black.
Oct 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Refilling canon iP 1880 color cartridge
Insert a fine needle through the hole and when the ink sticks to the needle withdraw it and rub on a white cloth and identify the color and mark the holes accordingly.
Jan 23, 2008 | Canon PIXMA iP1600 Printer
Canon I990 InkJet Photo Printer Logo
3,278 people viewed this question
old marine
old marine
