Question about Refrigerators
Milano I have a Dishlex Milano dishwasher, fantastic machine but of late it is filling with water without being switched on, and it also has been switching itself on after the water that leaks into it gets to a certain level, the only way I can counter act this is to switch machine off at power point and then switch it back on and push on one of the electronic buttons which makes it go into a pump out mode and I can get control over the machine again. Can you suggest what is wrong I have had this machine for 15 plus years and love it. I suspect it is a leaking inlet valve or solenoid.
  • herb1e726
    herb1e726 Nov 06, 2012
    Thanks Brad for your input, to further explain the machine leaks in water even with power off. Then if power is switched on and at no point in particular the machine will start unknown if the start is a cycle or not because at this point none of the buttons will respond including cancel button. I have to switch off the power completly and wait at least ten minutes before switching it back on to gain control over the machine , lol I think it might be possessed :)
  • Refrigerators Master
  • 16,195 Answers
If you can switch off the powere and it stops filling then it is not a stuck valve. It is more likely a power issue. There is a problem with the power supply inside the washer that is not filtering properly or the diodes are out and it is letting current into the valve when it is supposed to be off.
Posted on Oct 28, 2012
Leaking Milano Dishwasher
check all screws in door,and seals,also you might have a disconnected rinse hose in the door
May 13, 2015 | Dishwashers
Is there a way to unlock my kyocera milano without using the touchscreen?
The easiest way to unlock the phone is to just open up the Keyboard. It automatically unlocks and awaits your instruction.
May 15, 2014 | Kyocera Milano
Luna milano crib assembly instruction
Here is the link to the manufacturer's instructions page. Locate your exact model number (they are in alphabetical order) and download your manual. Milano Cribs by Pali Link
Jan 19, 2013 | Sweet Beginnings Bella Luna Milano Crib
Does advent milano w7 notebook have cd-rom
Netbook - No
Notebook - Yes
The Milano W7 is a netbook.
Dec 16, 2009 | Advent Netbook
The Bluetooth on my Advent Milano Netbook won't work, it doesn't pick up any bluetooth devices and other bluetooths can't find it
advent milano has bluetooth software but you have to buy third party hardware to plug in for it to work.
Nov 07, 2009 | Advent Netbook
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
Feb 14, 2009 | Zephyr Milano-S ZMI-M90S Kitchen Hood
Vulcan Dishlex Milano. Programs erratic. Normal wash does not admit water. Fast wash does not advance past rinse.
Problem proved to be gunk in the water level tank, tube and level switch. All were replaced.
Jul 22, 2008 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
