Question about HP 1901w Monitor
1901w white screen
Monitor will turn on but only displays a white screen, and does not show any menus etc when pressing buttons.
    Genius:
  • HP Master
  • 2,432 Answers
Tried to check first weather the connectors going to the display panel get loose or flex ribbon get broken. if those are ok, then the problem is the lcd board controller.
Posted on Oct 28, 2012
2 Suggested Answers
  • 489 Answers
SOURCE: my monitor display the odslockout message when i press any button
look at it you will find something about the issue.
http://ask.metafilter.com/73981/OSD-Lockout-OSD-Lockout-OSD-Lockout
Posted on May 29, 2009
Acer monitor screen showing partial screen only. rest of screen showing black & white dots.
Hello there.
Try the monitor with ANOTHER computer,
This will prove whether it is the Monitor at fault or not.
Sep 25, 2014 | Computers & Internet
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
I have problem with hp monitor 1901W display problem how can solve
Hook a spare monitor to the pc to rule out the video graphics card, if okay! the HP monitor has a serious issue, just to be sure! change the video cable from the monitor to the computer, if no change! the monitor will need to be repaced. There is a large circuit board on the back of the LCD it processes the video, colour, brightness and more and is apart of the display.
Apr 26, 2012 | HP 1901w Monitor
My computer monitor screen display turns from white to yellow due to my daughter pressing the different buttons on the keyboard.
Vanita "NAMASKAR"
Kids always do this.
But let us see, does your monitor turn on and off correctly? And also please describe the problem competently to understand well and help you? Like which key pressing will change the color etc.,
Just in the mean time do check the cable connected at the back of the PC
Saleem Ahmed
Jun 29, 2011 | E-Machines 17F2 17" CRT Monitor
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
White Screen
sounds like a faulty monitor,time for a new one,is it under warantee???
Aug 16, 2009 | Dell SE198WFP LCD Monitor
Acer al1711 shows only a white screen
These are pretty old now but I'll respond anyhow-
When there is absolutely no screen content and white, it means that ALL pixels are turned off; black, means all are turned on. If you have a white screen, it means that a component in the video stream has failed; a black screen (preferable failure!) often means that the backlight lamp or its inverter have failed. The latter is a potential DIY fix, a dead IC in the video path normally not since most of the signal chips (ICs) are placed and soldered by robots and the pin spacing on those is pretty much beyond the capabilites of an untrained hand.
The only exception I can think of is if the ICs no longer have voltage supplied to them from the main power supply but you would need at least a cheap multimeter to locate that.
May 31, 2008 | Acer AL1711 17" LCD Monitor
HP 1901w Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
