Question about HP Compaq Presario CQ62238DX AMD Athlon II Processor 156 LED HD Display 3GB DDR3 PC Notebook
Battery not charging
The laptop shut down the otherday now the light by the power in does nothing when the power lead is in but occasionally it will show the orange light or the blue but the battery isn't charging
  • HP Master
  • 27,725 Answers
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Posted on Oct 29, 2012
  • 13433 Answers
SOURCE: Battery shows 50% charge, but Laptop powers off
The battery is most likely bad. have you tryed another one?
Posted on May 23, 2008
  • 644 Answers
SOURCE: I have HP 6000 series Laptop although the blue
If the power cable is good and lighting up the indicator led then the problem is with your battery, take the laptop to your local pc store and ask if they have a battery that fits the laptop that you could test to see if that is the problem.post back your findings. cheers.
Posted on Jan 27, 2010
  • 788 Answers
SOURCE: Laptop suddenly shuts off and will not turn back
I have reviewed your problem and have the fallowing for you to aces.
First, if you have only had this unit for 5 or 6 months, get it back to HP under warranty ASAP.
I work for HP and we offer a 1 year standard warranty and a extended 1 year for Display and Graphic problems.
Please, do yourself a favor and contact customer care and they will send you a Box, per paid and will have the unit back to you within 1 working week, at no charge to you.
Hope to hear from you.
Let me know if you need anything.
Posted on Nov 05, 2009
faceofftech
  • 185 Answers
SOURCE: plugged in & not charging with new battery
Laptop not charging
if you have a brand new battery and it is not charging, check the charger you may have to replace the plug on both sides, check the cables.
you can take the charger to a TV repair shop and tell them to check it and see if there is any juice (charge) coming out of it. that is a common problem with chargers, we trip over the cable or pull it out of the laptop by accident and it brakes little by little. if there is no charge coming out you can star by checking the jack you may have to cut it and have them check it again.
if you don't want to go trough the whole testing, just tell the TV repairman to fix it it should cost you about 30 bucks instead of 80 for a new original charger or find a chinese one on e-bay
if it works for you don't forget to rate me
Posted on Apr 28, 2010
  • 219 Answers
SOURCE: Hi my hp 6735s laptop has just started turning
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
Posted on May 27, 2010
Toshiba satellite c55-b5201 won't shut down its stuck on shutting down but still hasn't and the battery light is flashing help i don't know what to do
Best to pres the power button for a few minutes to force shut down and restart.
If that doesn't work then remove power lead and pull the battery out and re-insert battery and power lead and restart.
Sep 16, 2014 | Computers & Internet
Flashing red light on Packard bell nothing works
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
May 25, 2012 | Packard Bell Computers & Internet
Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen...
take off : power cable , battery wait 5 min
open the case take off the c-mos battery , wait 5 min
mout everything , start the machine again , whit all connections , so you did a reset from your bios
Apr 18, 2017 | Acer Aspire One AOA110-1113 Netbook
My D620 starts to boot up then shuts down suddenly
could it be that your battery is no longer holding a charge?
try powering it up with the power pack attached (and ensure the light on the power pack is indeed lit) - it also could be that the laptop is not being charged by the power pack.
Jul 14, 2010 | Dell Latitude D620 Notebook
The fans run but the computer fails to turn on
Likely either a bad power connector (common) or the charging circuit on the motherboard may have a problem.
Oct 12, 2009 | Toshiba Satellite P35-S611 Notebook
No power
Hi there
Take the battery out and try to power the machine up on AC only,
Post back with the results please
Feb 01, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Advent 9912 wont turn on
remove the ac adapter
take the battery out
be sure nothing is connected with your laptop
then press and hold the power button for 60 secs to drain static as it is the most probable reason laptops stops working.
then connect the ac adapter only and without the battery try powering on the system
if it powers on
you can again shut it down
insert the battery
it should surely power on
Apr 20, 2008 | Dell 2600 Notebook
Laptop will not power on at all.
Don't know what you have for a laptop, so will have to give you a generic process, here. Power down. Remove hard drive, remove cd reader and/or floppy drive. Remove memory cards. Replace only 1 memory card in the main slot (probably marked as slot 1). Try to power it back up and let us know what happens.
Thanks!
Ron-
Nov 02, 2007 | Computers & Internet
Open Questions:
See all HP Compaq Presario CQ62238DX AMD Athlon II Questions
HP Compaq Presario CQ62238DX AMD Athlon II Processor 156 LED HD Display 3GB DDR3 PC Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
