Question about Dryers
Mounting Plate for Ceiling Fan
Purchased a USED Ceiling fan, there was NO mounting plate with the fan.
  • 14,378 Answers
Go to Home Depot or Lowes,they have fan parts.
Posted on Oct 28, 2012
5 Suggested Answers
Junoon007
  • 1011 Answers
SOURCE: Having problems mounting ceiling plate
Dear Sir/madam,
Click this link for instruction manual....check out....
http://www.belowcostappliances.com/info/fans/owners-manuals/wet-light/light-fixture.html
thanks
good luck
Posted on Aug 10, 2008
SOURCE: Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
Posted on Jan 16, 2009
SOURCE: I want to hang the fan on a cathedral ceiling with
The slope is measured off the horizontal plane. A 45 degree slope would rise 12 inches for every 12 inches of horizontal travel in this example. If the slope is too great try checking kits made by Fanimation. The Fanimation SCK52 - 52 Degree Ceiling Slope Ceiling Fan Kit will go up to a 52 degree angle ceiling and will fit most downrods. The hampton bay fans are very popular and should work just fine with this kit.
-Mark
Posted on May 14, 2009
  • 37 Answers
SOURCE: missing mounting plate
oh where did it go ?
http://www.sencart.com/Supply-home-lighting_c104
Posted on Apr 24, 2012
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Have KI 52 inch ceiling fan and need mounting ceiling plate any help would be appreciated
Kenroy Home11660 Central Parkway
Jacksonville, FL 32224
(904) 642-4340 Phone
call them for your part
May 04, 2011 | Kenroy International 9052.5AB Ceiling Fan
How to install a hampton bay ac416 fan
To give you details it may be necessary to get more information from you .. how many switches will be controlling this fan? how many and what color wires are there at the ceinling box? does this fan have a light kit with it?
The typical install is to screw the mounting plate or bracket to the ceiling box. Then the fan is assembled with the canopy cover placed over the down rod, if there is one. The fan usually hung from the mounting bracket and the wiring completed, and the canopy c over slid up and secured.
If a flush mount then the fan is humng on the plate and the wiring completed , then the fan secured to the bracket .. Any thoughts?
May 30, 2010 | Hampton Bay AC416-NI 56'' Frontera Natural...
I can't find any mounting screws or bolts on the ceiling fan motor assembly. How do I remove it from the ceiling?
Yopu first need to drop the canopy co0ver from the ceiling mount. The cover may have screws at the very top edge. It may have screws at the bottom plate. It may have a decorative plastic ring at the very top that is conceling the mounting screws. You should be able to twist the plastic ring in an unscrewing motion and pull down to remove it.
Mar 10, 2010 | Hampton Bay 24750 Huntington III Ceiling...
I would like to order a replacement light kit for this ceiling fan. Mine is Brushed nickel however
Hampton bay is an exclusiove brand of Home Depot. Yopu shopuld be able to get a new light kit to fit your fan there or try any lighting store or Lowes. You will need to bring the old one with you to compare the size of the mounting plate and the araingement of the mounting screws to the new kit.
Feb 23, 2010 | Hampton Bay 52 In. White Huntington III...
My Nutone 8814R motor went out on my ceiling fan and i just ordered a new motor. My question is how do i take out the old one and replace it with the new one. Will it be easy to do myself? Also is there an...
The good news is that this is a relatively easy item to remove and replace, as they make a replacement fan/motor unit (sub assembly) that you can swap out for the old one.
All you need to do is pull down on the trim vent plate and then squeeze the wire retainer clips together to remove the grill/trim.
Once you've done that, you can unplug the fan portion of the exhaust fan unit from the base enclosure. Now simply remove the screw or nut that holds the fan and mounting plate into the enclosure and simply pull it down and pivot it out of the enclosure - you might have to push in on the side of the enclosure where you removed the screw/nut to get the fan and metal plate out of the cabinet.
The replacement fans usually come with a new metal mounting plate that fits many of the older exhaust fans, but if your's looks different or doesn't work, you can remove the fan and install just the fan motore onto your old metal fan mounting plate.
Instructions are typically included in the replacement unit packages. This is also very simple to do with only 2 screws holding the fan onto the mounting plate.
Once you're done, simply hook the edge of the plate back into the fan enclosure and then push it up and fasten the mounting screw/nut onto the plate and plug the fan into the ceiling enclosure and replace the grill plate and you're all set!
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Broan-NuTone Deluxe 8814R Ceiling Fan
The motor burns and dont run its old,maybe ned to replace .i never don it, ned help, thanks
The good news is that this is a relatively easy item to remove and replace, as Broan makes a replacement fan/motor unit (sub assembly) that you can swap out for the old one.
You can get a replacement fan unit at most Big Box home stores (Home Depot or Lowe's) or at an electrical supply house. Just bring the old one with you so you can be certain you get the right one. The replacement fans come with a new metal mounting plate that fits many of the older exhaust fans, but if your's looks different or doesn't work, you can remove the fan and install the new one onto your old metal fan mounting plate. Instructions are typically included in the replacement unit packages. This is also very simple to do with only 2 screws holding the fan onto the mounting plate.
Oct 09, 2009 | Broan-NuTone N671 Nautilus Ceiling Fan
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton fan
You are probably missing a part. There should be a mounting plate...usually round...that attaches to the ceiling or electrical box. The mounting plate would have small tabs or a lip around the edge with threaded holes for attaching the cover.
Jan 16, 2008 | Dryers
Dryers Logo
Top Dryers Experts
