Question about HP Photosmart 2610 All-In-One InkJet Printer
Photo smart 2610 all in one scanner will not scan
I have a photo smart all in one printer, scanner , fax that will not scan. When I try to scan it gives me an error message that I need to install or run hp software for this feature. When I try to download the software it tells me the software is already loaded, In the past I have used scanner before without problems
  • bigdaddyguid May 21, 2009
    exact same error message all drivers (full feature) from the HP Canada website have been downloaded and installed, but the error message still shows. Printer shows in my printers and scanners window....still will not scan......
  • 53 Answers
Hey i also had this type of problem. but i solved it and hope it will solve yours too.
first of all uninstall all ur hp drivers and softwares related to the hp printer. then restart your pc. now disconnect ur printer with ur computer and turn it off and again on after 15 secs.
now insert the cd which i have got with the hp printer in the cd-driver of ur pc and install the driver.
after the installation is complete, connect ur printer, but do not remove ur cd.
then start scanning, and if it will again ask for installing driver, u dont have to worry it will install it from the cd.
this would surely help u, if problem persists, please tell me.
Posted on Jan 03, 2009
My photosmart 2610 all in one . When I try to scan it gives me an error message that says "switch off and start again". I did this several times but it didn`t work. And i have install and run hp software for vista but is not work !What shall I do?
Posted on Aug 26, 2011
SOURCE:
I can not scan on hp 2610 all in one?
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
or
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 27, 2011 | HP Photosmart 2610 All-In-One InkJet...
How do i get the scaner to work on my hp2610
Hi Good day!!!
The way it works for me (different HP all-in-ones, earlier photo smart) is I start Photo Smart, then (once it's loaded), I press the Scan button, and it scans (or brings up a scan menu on the little LCD on the scanner where I tell it to scan).
If this is what you're trying and it doesn't work, you might not have installed the software correctly. The scanner drivers are very picky about when you plug in the scanner to the computer during installation -- if you plug it in before the install program says to do it, the scanner won't work (though the printer will).
The thing to do in this case is (1) unplug the USB cable from the back of the computer, (2) go to control panel->add/remove programs, and remove the scanner drivers, (3) shut down and restart the computer (very important), and (4) put the HP CD into the computer and reinstall the scanner, only connecting the cable to the computer when the program tells you to do it.
Don't forget to vote thanks!!!
Nov 02, 2010 | HP Photosmart 2610 All-In-One InkJet...
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Photosmart 2610 with power on get Error 0x886a6916
0x error codes indicate that the product has an internal error. Try to reset the printer:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
Hp psc 1210v all-in-one printer, scanner, copier will not scan
CHECK BELOW OTHERWISE GO TO HP WEB SITE AND LOOK FOR THE DRIVER SUPPORT TO DOWNLOAD.
Scanning
Use one of the following three methods to scan a document. Method one: Scanning with Windows Photo Gallery
  1. Click the Windows (c01367376.gif ) icon.
  2. Click All Programs .
  3. Click Windows Photo Gallery .
  4. Click File , and then click Import From Scanner or Camera .
  5. Click Import .
  6. Click Scan .
Method two: Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise.
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scanning with Paint
  3. Click Accessories .
  4. Click Paint .
  5. Click File , and then click From Scanner or Camera .
  6. Click Scan .
Jan 13, 2009 | HP PSC 1210v All-In-One InkJet Printer
Scanner problems
try to change cableof scanner to pc.
Apr 01, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp photosmart 2610
is your operating system Vista.......good luck. my printer worked fine w/XP, scanning and fax functions do not work to date with Vista.
r2d2
Oct 28, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
933 people viewed this question
Clive
Clive
Thomas F. Schneider
