Question about Generac Honeywell 12kw Generator Sync/nexus Controller
I Have a Honeywell Generac 12 kw fuse blown
I changed the battery , checked the leads. Every time I put the new fuse in it blows, no power to the panel to start it. Not sure where to look for the short unit is 15 months old
4 Suggested Answers
  • 5 Answers
SOURCE: generator 30
fuse are meant to protect the costlier part of the machine thereby damaging itself.  there is probably overloading of your circuit. call the electrician and find the actual power required by your house.  there is a possibility of having a short circuit in your generator. your local electrician can check it.
Posted on Jan 24, 2009
  • 384 Answers
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
wentlanv
  • 710 Answers
SOURCE: Just returned from a trip
Hi Scott,
Since the generator starts but there is no power to the control board, there is an electrical problem inside the generator.
First check the circuit breaker at the back of your generator. If the breaker is on, then your generator is in serious trouble.
Call a repairman, but also keep in mind you may need a new generator.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 07, 2011
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Where are the exciting field wire fuses located
Try putting 12 volts DC across the commutator coils at the brushes, sometimes the generator looses it's magnetic field and this could possibly restore it but make sure it is a low current not a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5 kW, 60Hz Model PrimePact 50G RV...
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Generac 15000 watt generator blows 15 amp fuse when it try to exercise
a weak battery will cause the 15 amp system fuse to blow, even though the battery can still actually start the generator.
Nov 29, 2013 | Generac Electrical Supplies
20 kw generac is blowing 7.5 amp fuse,and all lights flashing.
You have a short: Check the wiring harness, check for shorted fuel solenoid, pump, rotor windings. Do this before replacing the control board
Oct 04, 2013 | Electrical Supplies
The cd player is not able to save eny thing like radio channals and every time when i start the car engin the cd make auto eject it mean that i have a problem with saving can u help me about this
you must have a digital volt meter and to find this out .
1. remove radio
2. take the volt meter and turn it onto dc voltage
3 take the black test lead and put it on ground for the radio it will be black find in harness on back of radio .
4 take the red test lead and find the yellow wire this is constant power must have 12 volt on wire doesnt matter if the car is running or off this wire is from battery it gives the radio power to save station presets and the clock and return the cd to were it left off from when radio turned off.
if no power at yellow wire go to fuse panel and use your digital voltmeter to check fuses for a blow fuse . take the meter turn it on meter to dc voltage and the take black test lead and find a good ground (clean piece of metal and then the red test lead start touching testing the fuses.
(turn your car ignition switch to run but dont start car) why some circuit in car only power up when you have car ignition on ....)
on the fuse there is the amp rating in the dead center on either side of the rating is the blads of the fuse expose to test the fuse touch the red test lead to the left and see if you get 12 volts. then test the right side of the fuse to see if you get 12 volts if not fuse is blown . do this to all the fuses untile you find a blow fuse you could just pull one fuse at a time untile you find blow fuse. if you do this make sure right amp fuse get back to the right spot in fuse pannel. if not you could have a fire maybe or melt something in car if a circuit fails and goes to blow fuse and fuse is too big and fuse doesnt blow ....
http://www.tintingbyfredjohnson.com
Dec 28, 2010 | LG LAC-M3600R CD Player
Generac Model 5525-1 20kw air cooled standby generator Question: How do you access the battery? I think it is behind the front panel, but can't readily see how to open/remove the front panel. Thanks!
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
Dec 04, 2010 | Generac Power Systems Generac 5525 20 Kw...
Dont have 12 volts to start switch generac guardian ultra source
Have you checked the fuse? Mine keeps blowing the fuse (located on the back of the control panel) with each startup and shutdown or use of idle control.
Jun 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Generator 30
Jan 24, 2009 | Generac Electrical Supplies
Generac Honeywell 12kw Generator Sync/nexus Controller Logo
63 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Don  Farrell
Don Farrell
Ottoniel
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
