Question about Whirlpool LTE5243DQ 24" Compact Thin Twin Electric Washer and Dryer
Thin Twin has a slow water drip when not running
When the machine is not running the wash tub eventually fills with water over a few days and runs onto floor. Other times, water appears to collect on floor in from of washer when not in use.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
If it drips while the washer is off then you will need to replace the "water inlet valve". Here is the part you need. Here is the service manual to show you how to access the valve and replace it.
Posted on Oct 28, 2012
Testimonial: "Thanks for your insight!"
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Water will not cut of it will run over when you turn onfor wash
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve. Here is the part you need for your machine. richroth_27.gif
Happy Holidays
Dec 13, 2010 | Maytag LSE7806A Top Load Stacked...
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Water drips into the tub from the inlet
Good day,
If water constantly runs or drips into the tub,even if the machine is off, then the water valve in the back of the machine, has one of the seals failing, and the water valve needs to be replaced.
Dec 22, 2009 | Maytag Washing Machines
Water drip
There is a water fill valve that allows water in, mixes cold and hot water or shuts it off. Its location is where the hot and cold water hoses connect to the washer.
Get the model number off the machine and go to the web site below and you can see the valve and also the cost of the valve should you choose to fix it.
http://www.appliancepartspros.com/partsearch/
Good luck, let me know.
Regards,
Jul 31, 2009 | Washing Machines
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Water in my washing machine
it sounds like you have a leaking water valve, you will have to replace the mixing valve, For now turn the water off at the wall suppling water to the machine. When you want to use the washer turn on water, when its done with the cycle turn the water off.
Note: unplugging the machine will not stop the water from running
May 13, 2008 | Amana 3.2 cu. ft. Top-Load Washer
u will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Sep 10, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool LTE5243DQ 24" Compact Thin Twin Electric Washer and Dryer Logo
334 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
