Question about Cisco 4015069 - Dpc2203 Modem 2pt Bmta Na Lps Btry Mult=15
How do i connect a wireless router to my cisco dpc2203c
There isn't a ethernet plug in to add my wireless router,so what should i do?
SOURCE: Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Posted on Aug 04, 2008
  • 8 Answers
SOURCE: ethrnet problem for cisco 1841 router?
Hi
You must enter the interface configuration mode and issue the command:
no shutdown
Posted on Mar 19, 2009
  • 233 Answers
SOURCE: I have a cisco router linksys. I connect internet
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Posted on Jun 08, 2009
prakas_3p
  • 107 Answers
SOURCE: Point to Point T1 Using Cisco 2800 Routers?
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
nkrcs
  • 94 Answers
SOURCE: no dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Posted on Jul 23, 2010
I have the Zyxel ngg-416n wireless router. when i connect it to my cable system and the the router to my mac, the computer doesn't 'see' the network connection. so i can't load the...
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.
Also check to see if your lan connection isn't disabled on the computer.
For starters
Aug 27, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
My wireless router is connected to the internet, but when i connect my computer wirelessly, it does not give an internet connection
Does the router let you connect to the internet if you plug into an ethernet port? Are you trying to use the wireless network while you are also plugged into the ethernet? If so, unplug the ethernet and try again.
Open a command window and type 'IPCONFIG /ALL' if you can see the IP address of your wireless connection, is this in the range 192.168.n.n (for example 192.168.0.3)? Can you see if the GATEWAY IP address is similar to that, such as 192.168.0.1?
Open a browser window and type the gateway IP address into the address bar. Can you connect to the router? (It will probably ask you for a userid and password)
Jul 26, 2011 | Linksys WRT320N Wireless Kit
I have a linksys SRW2024 24 port switch I am trying to run multiple linsysE3200 wireless routers off of it. For some reason they will not connect to the internet.
This isn't a basic switch, it's effectively a router that you must configure it accordingly: a long process in which you must log it and do all the necessary adjustments, starting with the IP assignations for the other routers and the ports settings. The entire process can be found in the manual, Chapters 3 and 4 If you need the manual
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
Jun 06, 2011 | Linksys SRW2024 24-Port Gigabit Ethernet...
Hi ya i have the problem tht i cant configure my router how to enter into it and give my password
print2.gif print email2.gif email
Title: Setting up your Linksys Router for the first time Article ID: 21463
Your Linksys Wireless-N Router comes with the Cisco Connect software which makes setting up and managing your Linksys Wireless-N Router a quick and simple experience. You'll have your Linksys Wireless-N Router up and running in no time.
NOTE: The Linksys E2100L router is only available in the U.S. For help on setting up a Valet or Valet Plus, please click here.
Some basic requirements before you begin
i. An active Internet connection.
ii. A computer with a wireless or wired Ethernet adapter, running one of the operating systems below.
- Windows XP with Service Pack 3
- Windows Vista with Service Pack 1 or better
- Windows 7
- Mac OS X Tiger 10.4.9
- Mac OS X Tiger 10.4.11
- Mac OS X Leopard 10.5.8
- Mac OS X Snow Leopard 10.6.1
Getting started
Provided that the above requirements are met, you can now begin setting up your Linksys Wireless-N Router. In this example, we'll be setting up the Linksys E3000 High Performance Wireless-N Router. The following steps will walk you through the entire process.
Step 1:
Your Linksys Wireless-N Router allows you the freedom of running setup via a wired or wireless connection. Therefore, please start by performing the instructions under the description that best matches the computer you're working with. Proceed to Step 2 once you're done.
Description A:
You are using a computer with no wireless connectivity that is normally connected with an Ethernet cable to your DSL/Cable modem.
Instructions A:
Please connect one end of the supplied Ethernet cable into the Ethernet port on your computer, and connect the other end into one of the numbered Ethernet ports at the back of your Linksys Wireless-N Router.
Description B:
You are using a laptop with a built-in wireless adapter.
Instructions B:
If you're using a laptop, please ensure that its wireless feature is switched ON, and that your laptop is positioned within 5 feet of your Linksys Wireless-N Router.
NOTE: Most laptops have a switch that turns its wireless feature ON and OFF. Refer to your laptop's documentation or online help if you're unsure where this switch is. This doesn't apply if you purchased an external wireless adapter separately.
Step 2:
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
Step 3:
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
© 2010 Cisco Systems, Inc. All rights reserved.
Nov 04, 2010 | Linksys Wireless-G WRTP54G Router
Do I need a wireless router to connect to the internet on a Toshiba L645D-S4056
Not strictly speaking.
You can use a wire instead if you have a port (hole) for ethernet plug (slightly larger than a phone port).
In coffee shops you'll be using wireless, but they provide the router.
Oct 28, 2010 | Computers & Internet
How to configure my router to ADSL2 modem router
- Windows 7
Getting started
Step 1:
Description A:
Instructions A:
Description B:
Instructions B:
Step 2:
Step 3:
Step 4:
Step 5:
Step 7:
Step 9:
Oct 16, 2010 | Linksys Wireless-G WRT54G Router
Jul 31, 2008 | Cisco (airap1120bak9airpcm352) 802.11b
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
Cisco 4015069 - Dpc2203 Modem 2pt Bmta Na Lps Btry Mult=15 Logo
56 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
