Question about Arris SURFboard SB5101U DOCSIS 2.0 Cable Modem - RoHS
Enable port 500
My verizon network extender says that if it's not working I need to enable ports 500, 4500, 53 and 52428 on the modem.
4 Suggested Answers
SOURCE: Ethernet Port seems to be a failure, but the USB works fine
I managed to fix the problem manually using a computer kit I had.
The problem was the Ethernet port on the modem was messed up
you should check if the small wires are on the back are all facing towards the top if not you should try to fix its actually pretty easy
no need to pay for a repair :D
Posted on Jan 31, 2008
SOURCE: Need to hook up Belkin G wireless router to Motorola SB5120
I have a Motorola SB5100 Cable modem and i have a belkin N wireless ROuter..i have conncted the wire from modem to router and computer to router and it doesnt work??what do i have to do??
Posted on Feb 26, 2008
  • 31 Answers
SOURCE: Need solution to Networking 2 comps thru an Arris
You will need to purchase a router my friend. The arris does not have a DHCP server built in and cannot assign IP addresses to the work stations. The only way that could work is if you ISP provided you with a second IP address, which would also be extremely unsafe from a security standpoint. Any wireless router should do the trick.
Posted on Apr 09, 2009
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
How do i turn off the router portion on my d-link 2750
Make sure ASUS modelRT-N13U wireless router is turned on then unplug your new router wait about 30 seconds then plug it back in.
It should find your wireless router.
Here is a web site with more trouble shooting advice:
https://www.asus.com/Networking/RTN13U/
Hope this helps
Feb 09, 2018 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
Verizon network extender netgear
please contact Verizon's Premium Technical Support and ask assistance for port forwarding if you want to use another router to your Verizon's network.
please contact 1-800-567-6789 and ask for Premium Technical Support.
May 15, 2012 | Westell Wirespeed Westell 7500 Dsl Modem...
Installed GS105 downstream of Belkin router. Verizon cell extender and an IP camera can't seem to negotiate a network connection through the switch. Direct TV console and A/V reciever can.
Don't use multiple routers in-line. Use just the one router connected to your ISP's modem, and then from there use Ethernet switches instead of routers. You're making a hash of your network by using dual NATs.
Feb 14, 2012 | NetGear Computers & Internet
I have a linksys befw11s4 router, and a verizon 6100G modem. I'm so confused I did what i had to do to get the router and modem activated and logged on to my router "192.168.1.1" then...
You will need to get the right User ID and Password before proceeding.
Also make your Verizon 6100G LAN port is connected to your BEFW11S4 WAN port.
May 09, 2011 | Linksys BEFW11S4 802.11b Wireless...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
I have a new HP Pro 8500 Premier. It says I need to open Port 427 to use wireless. How do I do that?
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
goto my network
chose the device you wanto to enable
http://portforward.com/english/routers/port_forwarding/Actiontec/MI-424-WR/Echolink.htm
if didnt work cll verizon tech suport
1 866 268 4630 ext 1112 direct line 24 hrs
Apr 17, 2010 | Actiontec GT704WG Wireless Router...
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
I had a lightning strike now my RZ26G wont connect to the internet. Verizon said to get a new ethernet card....i dont see one --- help how can i get back on the internet?
The ethernet card is embedded in the motherboard on this model,If you have a vacant slot on the motherboard you can install a new one there.any brand should do.
Good luck
Oct 22, 2009 | Sony VAIO Digital Studio PCV-RZ26G PC...
Arris SURFboard SB5101U DOCSIS 2.0 Cable Modem - RoHS Logo
76 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
