Question about Dryers
Printable instructions for remote control
Need printable instructions for lasko 5538 heater
  • 5,245 Answers
Lasko manual5155
The manual for the Lasko 5155 is available here: http://www.devicemanuals.com/productsupport/Lasko_5155_manual.html . You will need to review the heater to download the manual. Other Lasko manuals are available from the Lasko site. The current tower heaters have the manuals on their individual product pages. You can access the list here: http://www.laskoproducts.com/ceramic-tower-heaters/ . Other manuals can be accessed here: http://www.laskoproducts.com/?s=Manuals... .
I hope this helps.
Jan 07, 2014 | Heating & Cooling
I just bought the Lasko model number 6221 and there are no instructions. Should I take it back (there were not anymore of this model) or can I get instructions?
Here's a link to a Lasko page where you can download an Owners Manual. Unfortunately, the link from that page no longer works, However, there is a 800 number for customer service. They can provide you with the Owners Manual. Hope this helped you.
Mar 11, 2011 | Lasko Ceramic Heater
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
My Lasko 5805 heater worked fine and still works fine except the temperature shown is now in celius instead of farinheight
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Jan 02, 2011 | Lasko Ceramic Heater
I have a lasko model 5362. the lower control knob is cracked. i need a replacement. please advise.
That model is under recall. DISCONTINUE USE
Also models 5132, 5345, 5364, 5420, 5532, 5534, 5566. For recall information see:
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
Dec 03, 2010 | Lasko Heating & Cooling
The fan makes an odd noise as if it were out of
Recalled: Discontinue use and see
May 09, 2010 | Lasko 5362 Heater
Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Mar 04, 2009 | Lasko 5610 Baseboard Heater
Dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Jan 29, 2009 | Lasko 5365 Ceramic Compact Heater
http://laskoproducts.com/instructions/5364Ins5364ES.pdf
Here you will see what the buntons do.
Good Luck and Please rate Fixya!
Jan 08, 2009 | Lasko 5365 Ceramic Compact Heater
Lasko heater beeps too LOUD
I was cleaning out my Lasko ceramic heater 6000, looking for instructions on how to do so, and came across your comment. After I opened it up and cleaned everything out (really easy, no instructions needed, it is all obvious) I started thinking about how much I hate that beep as well. So I decided as long as I had it opened to try to disable it.
Well, I could tell from plugging and unplugging that it was (unfortunately) mounted on the under side of the green circuit board. You will have to unscrew the circuit board completely (all wires still attached) and (carefully!) move it so you can flip it upside down to get to the other side. Note: there were 7 screws to remove and 1 was under the motor and really hard to get to. The motor looked WAY too complicated to remove so I got the screw started just a little with a precision screw driver and turned it the rest of the way with needle nose pliers.
Once the circuit board is off, the beeper is a little black circular thing (about 1/2 inch in diameter) with a little hole in the middle. It has a serial number on it and a "+" symbol. It looks like it is built in two pieces (upper and lower), so I tried to carefully remove the upper piece with needle nose pliers while leaving the lower piece connected to the circuit board. Well, the whole thing ripped out! I thought two things: 1) It will never beep again, and 2) I hope this didn't break a circuit causing the whole thing to fail.
Well, I put the circuit board back on ( I left off the one difficult screw, as 6 of 7 is more than sufficient to hold it on). Put the whole unit back together, and . . . . IT WORKS FINE!!!!!
Nov 30, 2008 | Lasko Ceramic Heater
Dryers Logo
88 people viewed this question
Top Dryers Experts
