I have a Samsung BD-HDD Combo connected to Samsung LCD TV Remote is working except for the Home screen option.it doesn't show the OSD required.
chrispurs1
  • 372 Answers
SOURCE: Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Posted on Jan 08, 2008
  • 5 Answers
SOURCE: Akai 27" wide screen LCD/HDTV/DVD Combo
Some 1000uf electrolytic capacitors have failed on the power supply board (3x 16v & 2x 35v radial). You can get them at Radio Shack or your favorite parts house.
They are easy enough to replace if you are handy with a soldering iron. If not, bring the tv to a repair shop & tell them that you want the capacitors replaced on the power supply. It shouldn't be too expensive.
To get to the power supply, unplug the set from everything including power. Put the set face down on something soft that won't damage the screen. Remove all the screws from the rear cover, they have arrows pointing to them. When you get to the dvd player, care will be needed to get the cover off.
The power supply board is on the upper right side of the chassis and is not covered by anything. Look for the capacitors that are "bulging" on the top. These will need to be replaced. Good ones look flat on top.
Remove the bad capacitors noting there orientation (they are polarized). The "negitive" side will have a "band" printed on the capacitor. Go get the new ones & replace them carefully aligning the polarities correctly. Reassemble the case & you should be done.
Good luck. al
Posted on Feb 01, 2009
  • 8457 Answers
SOURCE: I just bought a Samsung LCD TV, and have Insight
Yes,Samsung is Korea,Sony is Japanese.Read both manuals carefully,goes to there websites for idea or back where u buy it for more imfo.
Posted on Sep 29, 2009
  • 8457 Answers
SOURCE: Toshiba 23HLV85 LCD TV/DVD inverted image
Yes,Ur main Tuner board have problems,the ICS on the board is not coverting.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Apr 14, 2010
dcramer531
  • 1654 Answers
SOURCE: My child pressed buttons on
These instructions should get your set unlocked, if not there is a number to contact omni for technical support, some times these locks may be a software issue.
  • Use the original Omni remote control to turn on the TV. You need the original remote to bypass the child lock. A universal remote won't work.
  • 2
    Check the screen. If you see a blank screen with a red key on it, press the "Function" and "Mute" buttons at the same time. This unlocks only the channel that is on the TV. All the other channels will remain locked and the TV will lock again when it is turned off.
  • 3
    Unlock all of the channels on the TV by entering "6688," which is the factory reset code. This code resets the TV to original factory settings. Once this is done, you will have to go through the initial setup.
  • 4
    Call Omni technical support at (416) 260-0047. A technician can help you troubleshoot the television as the problem may not be the child lock. You'll need to know the model number and serial number of the TV.
  • I hope this resolves your issue.
    Posted on May 21, 2011
    I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
    Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs. http://electronicshelponline.blogspot.com/
    Inform them the problem you faces with the TV. They will surely provide a solution.
    Nov 25, 2014 | Samsung Televison & Video
    No OSD menu on Panasonic ST50 plasma TV
    My guess is that the OSD function can only be enabled directly at the Panasonic TV.
    Nov 18, 2013 | Yamaha Audio Players & Recorders
    Samsung DVD Player remote buttons activate Samsung TV settings
    To do a reset of the remote control follow the instructions below.
    1. Remove the batteries from the remote control.
    2. Hold down the Power button for a full minute.
    3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below
    1. Press the BD button on the remote control then press Home. This should bring up the home screen.
    2. On the Homescreen, choose AllShare Play and press the Enter Button.
    3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''.
    4. Now the titles of the recorded programs will appear.
    5. Press the Tools on the remote control and select ''Delete'' from the side menu.
    6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control.
    7. Select ''Delete'' from the side menu then confirm deletion.
    To try and resolve this issue, please reset the remote control. To do so, please refer to the instructions below: 1. Remove the batteries from the remote control. 2. Hold down the Power button for a full minute. 3. Once done, put the new batteries back in and test the remote control. Please power cycle the unit as well by unplugging it from the wall and leaving it of for a couple of minutes. Once done, test the remote control again. To delete the recorded programs, please follow the steps below: 1. Press the BD button on the remote control then press Home. This should bring up the home screen. 2. On the Homescreen, choose AllShare Play and press the Enter Button. 3. On AllShare Play, scroll down to Recorded TV and choose ''HDD''. 4. Now the titles of the recorded programs will appear. 5. Press the Tools on the remote control and select ''Delete'' from the side menu. 6. Select the titles to be deleted by highlighting them, then press the Enter button on the remote control. 7. Select ''Delete'' from the side menu then confirm deletion.
    Jun 27, 2017 | Samsung LA40A550 40 in. HD-Ready LCD TV
    Lg tv cf20s12e
    CHECK TV OSD(ON SCREEN DISPLAY ) SETTING
    Jul 19, 2013 | Televison & Video
    I want to set my samsung home teather remote to my vizio tv the remote is a ah59-02291a
    hi,
    Need the model number of the samsung Home home theatre system to give to correct code.
    OK
    Aug 13, 2011 | Televison & Video
    Samsung Remote Control not working
    any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
    Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
    how to tune in the sky remote to work your samsung tv
    TV,
    RED + SELECT ( blinks twice)
    TV,
    0060
    TV,
    SELECT.
    Job done
    Hope this helps you out.
    Cheers
    Little Dish Fitter
    Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
    LCD LG TV 37LG50 / Samsung bd-p1500 blue ray player
    644 works with the Samsung BD-P1590/BD-P1590C/BD-P1600 om my Blue Button Dish Remote for the 722k.
    Dec 28, 2008 | Televison & Video
    I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
    If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
    Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
    Need vizio code for Samsung remote!!
    I have a 37 inch vizio and had the same problem. After a little web research, I came across a suggestion that the LG codes might work. I tried it and found that the code 19 worked. You might try that. If 19 doesn't work for you, one of the other LG codes might (they are 06, 21, 22, 23 or 78).
    Jul 25, 2008 | Zenith ZEN700 Remote Control
    Televison & Video Logo
    352 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
