Head light adjusting
SOURCE: head light adjustment
The adjustment screws/nuts should be located either on the top of the headlamp assembly,
behind the headlamp assembly, or near the frame rail by the radiator
support.
You will have vertical adjustment screws for each independent beam
(separate highs and separate lows, but will be same screw if highs and
lows are the same bulb). You may also have additional horizontal
adjustment screws as well
Park
your car on a level ground 30 feet from a wall and measure the height
from the ground to the bulb and mark on a wall (do this for highs beams
and low beams if the bulbs are separate, if highs and lows are the same
bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then
aim the brightest part or cutoff part just below the mark on the wall.
If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
