Question about Nintendo Wii Console
When I try to point my wii remote at the tv screen straight it won't show up, I have to hold my remote far to the right to get the hand to appear straight on the screen. How do I fix this?
Problem with my Wii Remote and possibly my Wii Sensor Bar
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 11 Answers
Make sure that your sensor bar is straight, and not on an angle. You may have to contact Nintendo if this problem occurs.
Posted on Dec 26, 2012
4 Suggested Answers
maxicube
  • 51 Answers
SOURCE: Wii remote - upside down???
this is a solution that fixes it.
while the remote is upside down whack it several tims 4-7
and then reset the controller.
hope this helps,
Maxicube
Posted on Feb 10, 2008
ipodfreek
  • 64 Answers
SOURCE: The cursor jumps around the screen
Reposition your Wii so when you play you aren't pointing the controller toward a bright light (like a window or lamp). Bright lights freak out the controller. I have a huge window in the room with the Wii, and I have to wait until mid morning on sunny days or it's almost impossible to control.
Posted on Jan 17, 2009
  • 18 Answers
SOURCE: Wii not picking up signal from wii remotes
are you having this problem at the wii menu or during game or the hbc?
some games only allow for a certain amount of wiimotes to connect to the system (usually 1 or 2)
if it has a problem with the hbc (HOMEBREW CHANNEL) then some programs only allow gamecube controllers to work.
Posted on Jul 06, 2009
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
I am trying to put Internet on my wii. How can I get it to pick up my wifi
From the wii home menu...
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again. Then, click the one you have access to...
When the following screen appears, click OK...
and OK again.
It will test the connection...
And if successful, the following will drop down. Click Yes to update Wii.
Sometimes the above screen is false, saying there is an update when there isn't and the following will appear...
Now, back in Wii System Settings, click on WiiConnect24.
From the following list click WiiConnect24.
Click On and then Confirm to save your settings. This feature allows for updates to be seemlessly sent to your Wii so you don't have to do the final step every time.
Ok, the final step, just as a way to make sure your Wii is up to date. Click the right arrow from the 2nd page of Wii System Settings.
Click Wii System Update...
click yes...
it will test your connection for a few seconds...
an update screen may quickly come up and tell you there is an update (whether or not your Wii actually needs one)
and the following screen will appear. Click Wii Menu to finish.
Dec 08, 2011 | Nintendo Video Game Consoles & Games
AOC A15X221 have picture no sound
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
Programed the first wii remote but the arrow (on the game on the television) keeps dissapearing. what do i do now? does this mean the remote is not hooked up correctly?'
Press the home button on the Wii Remote and point at the screen. If the hand does not show up, there might be a problem with your Sensor Bar. Make sure it is plugged in correctly, and the Wii Remote has a clear path to it.
If the hand does show up after pressing the home button, it might be that the game is not meant to show a cursor when you point at the screen.
Aug 21, 2011 | Nintendo Wii Console
How do i conect my dsi to internet
and OK again.
click yes...
Jul 19, 2011 | Nintendo DSi White Console
Can i connect a pc to a wii to view pc screens a my tv
Instructions things you'll need:
  • Wireless router
    • 1 Determine if your Internet connection is compatible with the Wii's online console features. If you are using a dial-up connection you will not be able to connect to the Internet through the Wii console. The best connectivity is with a cable, DSL or fiber-optic connection.
    • 2 Start up your Wii. Go to the main menu. Click on the Wii icon button on the bottom left side of the screen.
    • 3 Select the "Wii Settings" button with a wrench icon. Go to the "Wii System Settings" menu.
    • 4 Click on the arrow on the right side of the screen to scroll to page two of the settings. Click on the "Internet" tab.
    • 5 Select "Connection Settings" from the menu that appears. Your screen should show three connection slots all saying "none" next to them. Select "Connection 1."
    • 6 Choose "Wireless Connection" from the pop-up screen. A new screen will appear that reads "Search for an Access Point," "Nintendo Wi-Fi USB Connector," and "Manual Setup." The easiest way to set up the Wii online is to select "Search for an Access Point."
    • 7 Wait a moment for your Wii to find an access point. When the words "Choose the access point you want to connect to" appear on your screen, click "OK."
    • 8 Pick your access point. Choose the point that is listed with a green signal strength icon.
    • 9 Save the settings by clicking "OK." Your Wii console will perform a test. A window will pop up asking you to perform a Wii system update.
    • 10 Complete the system update. Read and agree to the "User Agreements." You should be able to view movies, TV shows, websites, news and games from your PC on your TV.
Apr 17, 2011 | Nintendo Wii Console
Pokemon Battle REvolution rental can't start the game
it could be simply that the remotes are not turned on.or it could be that they are not pointing it at the motion sensor or they are standing too close.
I would advise to stand atleast 5 feet away from the screen
note that the blue pokeball is the wii remote pointer
Mar 01, 2009 | Nintendo Pokemon: Battle Revolution for...
Wii remote hand not showing up on screen
on the front of the wii theres a red button you have to keep you finger on that for 5 seconds and try again this has to be done everytime u have to sinc a different device.
May 08, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
