Question about General Electric Profile DPSE810EGWT 7.0 Cu. Ft. Electric Dryer - White
My dryer comes on, heats up, etc but the drum won't turn. Is it the belt or bearings or both?
  • Karen Hinton Oct 29, 2012
    i can spin the drum by hand
    Top Expert:
  • GE Master
  • 9,472 Answers
Can you spin the drum by hand or is it locked up?
Posted on Oct 28, 2012
    I can spin the drum by hand
vanni7
  • 163 Answers
SOURCE: dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Posted on Jan 04, 2009
MNTECH
  • 1543 Answers
SOURCE: replace bearing and bushing g.e. profile dryer
Yes, but you will have to swing the top open, remove the dryer front, and pull the drum forward about 4 inches (leaving belt on drum) to gain access to the bushing. Normally that is all you have to replace, but also check for wear on the front drum slides at the same time.
Posted on Jan 21, 2009
  • 163 Answers
SOURCE: GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
dmftrucker
  • 1922 Answers
SOURCE: Dryer Drum bearing designs
these drum glides look cheap,but they last for a long time
Posted on Jul 29, 2009
  • 54 Answers
SOURCE: How do I get my model 453 dryer apart to replace
Open the door. Remove the two screws holding the top down. Lift the top, this will give you access to the two screws holding the front on. Goodluck.
Posted on Nov 07, 2009
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
Dryer turns on but drum won't turn
Remove the top to see if the belt is intact. If it is, you will need to replace the motor. Here is the motor to order.If the belt is broke, here is the belt to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 11, 2012 | Dryers
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
I can't remove the drum from my frigidaire. I took off the top and front panels, and I tried to pull the drum up and out but it won;t come out. Is there a bracket in the back that I have to release?
no,there's a rear bearing on the drum,if you can't get the drum out remove the three screws inside the drum,this will separate the bearing from the drum,you have to push up hard first on the drum,it's sitting inside a cup that the bearing rides on,use the belt to pull it up.
May 08, 2011 | Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
General Electric Profile DPSE810EGWT 7.0 Cu. Ft. Electric Dryer - White Logo
248 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
