Question about Malber TD700 Electric Dryer
Dryer not spinning
The on light is working, last week it was having trouble spinning and than it was fine but when I went to open door the door handle broke iff. it has been working intermittently since but now it not rotating at all.
3 Suggested Answers
SOURCE: DOOR HANDLE
Email Malber at info@malberusa.com
Posted on Aug 07, 2008
  • 6277 Answers
SOURCE: malber washer dryer 800 handle
As the handle will have to be replaced I would suggest calling for a service engineer is the only option ;-0(
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry and good luck.
John C
Posted on Mar 25, 2011
Why does dryer spin with door open?
Hi Mandy,
The fact that the light bulb is out *and* the drum continues to spin when the door is opened - all point to a faulty door switch.
This switch tells the machine the "status" of the door position. When the door is open, it turns on the light *and* stops / prevents the drum from starting. When closed, the light is shut off *and* the drum is permitted to spin. You should have the switch serviced as if a wire came loose it adds a potential shock hazard - in addition to the safety issue of placing hands into a spinning drum.
Jul 10, 2013 | Dryers
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
The door was working fine for 8 years, last week it went down to about 2 inches from the floor, then went back up. No obstructions. I the started to adjust the chain...bad idea. Now in is inconsistant...
If this is a wood garage door (as opposed to steel), the problem may be that the door has become heavier. It might even be sagging enough to interfere with smooth operation. The added weight could be from being recently painted or the paint finish has gotten to the point where it's not sealing the wood anymore, so it's soaked up the summer humidity. Call an overhead garage door service company to take a look at it. They can probably make the adjustments to get it working. Then you might want to wait until a couple of weeks of dryer weather in the fall before you repaint the door.
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Went to try on the dryer and nothing! worked fine the last time I used it last week. what could be wrong?
main thermal fuse in the rear of the machine, if this tests good,, check the safety switch on the door itself you can hold it in and turn the machine on,, if it works,, replace the plunger shaft that turns it on
Aug 02, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Door wont open
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Jul 22, 2009 | Whirlpool LHW0050PQ Front Load Washer
Inside driver's door handle won't open door. Over the past week it seemed like the door didn't open until the handle was pulled further and further back as time went on. Now it is just"floppy" and won't...
you will have to remove the door panel. It is likely the metal rod inside from latch to handle is jarred or fell off. The panel will pry off if you remove all the screws in the door panel and remove lock and window controls.
Jun 30, 2009 | 1999 GMC Suburban
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
The light burned out last week and now the dryer won't turn on
Some dryers that have an interior light that is controled by the door switch, check the light to see if it's burned out, if it's not your door switch may be bad, when you open the door the door switch allows the interior light to come on, when you close the door the door switch shuts the light off, a bad door switch will not allow your dryer to start.
Feb 28, 2009 | Whirlpool LER4634J Electric Dryer
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Malber TD700 Electric Dryer Logo
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
