My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work.
My optavision hd 9500 projector's light doesnt come on, have changed bulb still won't work. what do i do
Posted on Mar 17, 2013
2 Suggested Answers
  • 979 Answers
SOURCE: I have replaced the lamp
Hello C navor hi, my experience with projectors, tells me that there is problem with the power supply section, Have it check for short on the regulator section, this could be anything from bulging capacitors, open resistors or the power regulator, the red means that there in no power going to the main board and the power supply section is on standby.
Posted on Aug 03, 2010
Optavision hd 9500 and turns on but no light. Replaced bulb and still no picture. Is there a contact number to manufacture for tech support or do you recommend a different avenue to solve problem
Check and replace the ballast board. Check whether any voltage is absent to this board, from the main power regulator board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Televison & Video
Backing light won't work
Change the bulb maybe?
If this doesnt work, have a look at he contacts, since its a 97 the contacts could be rusted. Just get a piece of sandpaper and clean it up, should be good.
If this doesnt work, may check the voltage of the wiring loom.
Hope this helps.
Owen.
Jan 11, 2013 | 1997 GMC Sierra
My optavision 9500 hd projector lamp does not come on even though the indicator shows green light. I changed the lamp,but result is the same. Can anyone suggest what the problem may be?
Check with a multimeter if the bulb socket is getting power (CAREFULLY). If not, that is the problem. The relay that turns on the bulb is blown or the fuse to it is blown...check them out...
Jan 01, 2013 | Office Equipment & Supplies
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
My Optavision 9500 HD light will not come on when power up, it is not even a year old and doesn't get used often. So what does anyone suggest?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 25, 2012 | Computers & Internet
Optavision hd 9500 lcd projector light will not come on
Can someone please post the manual for an optavisionn HD-9500?
May 24, 2012 | Office Equipment & Supplies
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
My PT-LB10SVU projector quit working and I thought it was the bulb so I installed a new one but it still does not work (no light), what do you think it is or where can I send for repairs, I live in Surrey,...
Welcome to Fixya. After changing the bulb and still won't work it can be that the problem is with the either the parts of the board or the mainboard itself. You can send it to repair to check which part needs to be replaced.
Panasonic - 604-533-5050
317-19292 60 Ave, Surrey, BC V3S 3M2
Panasonic.ca
3033 King George Blvd, Surrey - (604) 531-8331
Thanks for using Fixya.
May 26, 2011 | Panasonic PT-LB10SVU Multimedia Projector
864 people viewed this question
k24674
jasbo
jasbo
