Question about Ariston Technologies Washing Machines
Ariston Aqualtis AQXXD149 error codes
I have an Ariston Aqualtis AQXXD149H washing machine, it keeps giving me two error codes F1 and F11 and saying the machine is blocked. I have checked the hoses and water does flow but only for 10 seconds then I get the error and everything stops? Any suggestions? Anyone know what the two codes mean?
  • Kent Duncan Oct 28, 2012
    Disregard this issue, the mother board/ ECU let out some factory smoke and now I have no lights or anything. Will have to replace entire washing machine I think??
  • 183 Answers
SOURCE: cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Posted on Aug 22, 2007
Coldcut
  • 1554 Answers
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Posted on Jan 29, 2008
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
SOURCE: Hotpoint aqualtis giving H20 error
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Posted on Jan 11, 2010
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Lavadora aqualtis error11
    F11: Pump Feedback Missing
    Overhaul CN1
    Overhaul CNF
    Overhaul Pump Connector
    Overhaul Pressure Switch Connector
    Control Pump Windings
    Replace Pump
    Replace Card
    Dado
    Jun 25, 2014 | Ariston Technologies AWD 129 NA Washer/...
    Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
    If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
    May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
    Lavadora secadora ariston aqualtis aqm8d error f13
    F13: NTC wiring harness disconnected from the dryer system
    1. Check the efficiency of the terminals on the CNA connector board
    2. Check NTC wiring harness
    3. Check the wiring harness continuity of the CNA / NTC connectors
    4. Replace NTC
    5. Replace terminal board
    Dado
    Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
    Ariston aqualtis aqlf9d
    PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
    Jan 04, 2014 | Washing Machines
    Hotpoint aqualtis error code F04
    Indesit (Hotpoint Aqualtis, Ariston) 'F04' states 'pressure switch jammed empty, check pressure switch, wiring and module connections'.
    It is not that unusual to find it cured by having the connections gently pulled apart and replaced, thus 'cleaning' the contacts back to correct operation ;-0)
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck,
    John C
    Oct 05, 2011 | Washing Machines
    Hotpoint Aqualtis Error code F11
    please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
    Jun 27, 2008 | Washing Machines
    Washing Machines Logo
    312 people viewed this question
    Top Ariston Technologies Washing Machines Experts
    Darren Moxam
    Darren Moxam
    Gerry Harvey
    Gerry Harvey
    Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
