How to start in bios systems - Computers & Internet
  • 27,725 Answers
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Posted on Oct 29, 2012
My laptop asus g1s i need password bios for it I'm not putting it but it show after i fixed i problem in Graphics card
you may have had a bad graphics card. if it workes after changing the graphics card, the bios is still locked, but not for use when powering on the system. without a regular bios password, you cannot enter the setup from the startup menu. with a bios security password, you will need a password to unlock the screen preventing it from starting, this password can chain to a hard disk password unlocked by placing the system security password, which will then provide a prompt for the hard disk password. :) one locks the setup for the whole system. one locks the system from starting up, and one locks the hard disk from being read. there are three. without knowing the password, if the computer will not start and load your system, ie windows mac osx, you can have someone retrieve the password, or change the motherboard. if it starts, most people don't worry about it. if it cost more to have someone resolder the bios chip, replace the main or motherboard. if it starts and runs, use it and don't worry about it. :)
Nov 21, 2015 | ASUS Computers & Internet
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
Solution system bios shadowed video bios
To "shadow" is to use a small amount of the RAM to hold a copy of the system-BIOS and the video-BIOS areas. This usually speeds-up the computer, i.e., use RAM that is faster than the RAM on the motherboard.
Nov 04, 2013 | Compaq Computers & Internet
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Forget password acer aspire 3610
Acer laptops are equipped with a BIOS utility. The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer. On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings. If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair. Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt." The Windows Start button is located in the lower-left corner of your computer screen. Double-click on "Command Prompt" to open the application. You will need to use MS-DOS commands to reset the BIOS password. Type the following commands one by one in the order shown: debug o 70 2E o 71 FF quit Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands. Reboot your computer by clicking "Start," "Shutdown," and then "Restart." The BIOS password will now be reset to default. or To get into your computer's Basic Input-Output System (BIOS), your computer must be on, but your operating system cannot be running. If the Microsoft Windows operating system has even started to load, you will not be able to access your BIOS. This is why getting into the BIOS on an Acer Aspire netbook computer must be done specifically during your computer's initial boot-up sequence, which happens immediately after pressing the power button on the device.
Turn on your Acer Aspire. Press and hold the "Ctrl" key. Press and hold the "Alt" key. Press and hold the "Esc" key. This key combination will open the BIOS on your Acer Aspire.
Feb 03, 2013 | Acer Aspire 3610 Notebook
Bios problem
you have to remove bios battery once. after remove start your system enter to bios its all resetted. switch off system and put bios battery and restore default setting for bios.
Jun 17, 2010 | HP EliteBook 6930p Notebook PC
Graphics card has error code 10 (device cannot start) on boot. Screen resolution is terrible, I've uninstalled and reinstalled driver. still not working
Hello
I found this solution for you on Nvidia's site, the say it is only a simple setting in the bios at start up.
Here it follows:
The Code 10 error is most often a result of not having the option "Assign IRQ to VGA" enabled in your motherboards system BIOS. Please note: Making changes to your system BIOS can cause your computer to malfunction or become inoperable. If you are unsure how to make BIOS changes, don’t. Seek assistance from your system administrator or technician. If you are familiar with making changes to your BIOS, you may proceed with this section.
To enter the system BIOS for most PC’s, you need to repeatedly click the “F1” or “Del” key on your keyboard as soon as you turn on your computer until it brings you to the system BIOS. If this does not bring you to your system BIOS, consult your motherboard manufacturer or system manufacturer for more information. Once inside of the system BIOS, search for the option “Assign IRQ to VGA”. Check that this option is enabled and then save these settings. Exit the system BIOS and boot back into Windows. The error code should be gone.
Please rate the solution.
Best regards
Sep 15, 2009 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
My laptop beeds a restart, but i always get
It should also indicate which key to press to get into system configuration (usually Del, F1, or F2). Go through the settings and find "Shadow System BIOS" or something similar and set it to disabled.
BIOS Shadowing copies the system bios from ROM to RAM when the system starts, and is un-necessary in modern computers.
Sep 09, 2009 | Fujitsu Computers & Internet
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
System Freeze
sc122870, try this first disconnect the hard drive cable and then try getting into bios, also try disconnecting both cables to the cdrw and to the hard drive and try to get into the bios. Sometimes if the pin assignments on the 2 drives are wrong, bios will freeze. If it does the same problem with the 2 drives unhooked then it might be your mobo.
Aug 19, 2006 | Mach Speed P4MBMS Motherboard
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
