Question about Maytag Performa PAV2200
Wrong load setting caused washer to stop - Maytag Performa PAV2200
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Try to unplug the unit for a half hour then plug it back in and let me know what happens.
Posted on Oct 28, 2012
2 Suggested Answers
  • 4 Answers
SOURCE: Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Posted on Mar 31, 2012
My washer stops &and F-20 appears on viewer. Whats wrong with my washer
water problem check screens in hoses and valves !! rrors F1, F11 and F20
  • Error F1 indicates a communication error between the computer and the washer. Unplug the washer for a minute and plug it back in, as this may correct the problem. Error F11 indicates a motor control error. It can be caused by improper voltage. Unplug the washer and check the connections. This may fix the problem. Error F20 indicates lack of water entering the machine. If there is no water in the washer, check that the water valves are turned on. If there is water in the washer, press "Stop" twice to drain the washer. Unplug the machine and check the hose connections.
Read more : http://www.ehow.com/info_12006668_error-messages-kenmore-he2-plus.html
Feb 21, 2015 | Kenmore HE2 Plus Front Load Washer
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
My Whirlpool Cabrio top loading washing machine stops with an error OL . nothing wrong with the loading, this is only a small whash. Where is located this sensor for overload?
The sensing is done by measuring the motor amp draw. If the motor amp draw is high that is an indication of a heavy loaded washer which could cause the motor to overheat OR too much soap being used, OR the wrong soap being used, OR something between tubs. If you is getting an OL and the clothes is not the problem then you may have an item lodged between the tubs. You must remove the inner tub and get that thang outta there. Cabrio service manual
Rate it or hate it!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stopped in rinse cycle.
Sounds like a control or door lock problem. Try resetting you ccu ( computer control) by unplugging the unit for 30 minutes first. If this does not work then you probably have a bad door latch or bad ccu. You should have a technician do this repair. The wrong soap will not cause this problem, although it can eventually cause other problems. Good Luck, Appliance Specialists
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
IMaytag neptune washer stops at every cycle
Unplug the washer for 10 min to reboot the curcuit board. This will clear the little brain of any unwanted commands. Selecting too many cycles in a short period of time in frustration can overwelm the little brain. This can also happen with power surges from the electrical company. Undervoltage or overvoltage can cause similar problems. Rebooting clears the memory in the board and starts from scratch.
Apr 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Will not run continuously!
Either you have a faulty module or timer switch the dial used to set the wash program. If for any reason it ha been turned in the wrong direction your machie can behave exactly as you describe. Hope this helps.
Jul 29, 2008 | Kenmore 24932 Top Load Washer
Washing Machines Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
