Question about Aiwa BMZ-K1 CD Shelf System
Mode error 2
I can not insert o eject a cd .. the display say "Mode Error 2"
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Qx56 2004= trying to load a disc but when inserting about 1" of disc in, system said push eject. I pushed eject but then system switched to FM mode. Now I cant switch to CD mode when push CD button....
Sounds like that the cd is jammed inside the players so you could either take the player out the dash and open it up yourself or take it to a dealership/repair shop for them to fix it for you.
Also there might be a small holes located under the cd slot big enough for a pin to release the cd manually?
Jul 29, 2011 | 2004 Infiniti QX56
2005 Corolla cd player "ate"
try disconnecting the battery for a few minutes to reset the radio. Sometimes a microprocessor will lock up. You can reset it by disconnecting the battery.
Jun 01, 2011 | Car Audio & Video
I have a 2008 ford fusion. i just loaded a cd into in dash cd player and it now comes up with a "load error". i tried to eject it as well and it tells me "eject error'. it took my cd but it...
See if the cd is not fully inserted, take another cd and gently try to put it into the cd player to push any stuck cds back in. If this does not work you will need to replace the radio.
Feb 28, 2011 | Car Audio & Video
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
My cds won't play and they will not eject. I have an in-trunk cd changer.
If your radio works and you press mode .Does head unit recognize cd,s
It should display no cd,s cd error etc
The reason i ask this is to confirm that connection is ok to stacker
To eject PRESS AND HOLD eject button,insert credit card under cartridge,push fully in and move left/right untill eject
This will locate micro switch,so you can check discs
Jan 25, 2010 | 2004 Mitsubishi Endeavor
Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
May 09, 2009 | Computers & Internet
Kicking out disc "error 3" displayed
is it a burned cd? cause some cd players dont play burned ones. let me know if this helps
May 07, 2009 | Car Audio & Video
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
Aiwa BMZ-K1 CD Shelf System Logo
74 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
