I have a 32 inch flat screen tv by element, and I kind of dropped it and now all I see are diffrent color lines but I have sound! Did I miss it up?
  • 8,617 Answers
Are the lines running from top to bottom? If so it could be the LCD panel is broken or the Tconn connections to the panel are loose.
Posted on Oct 31, 2012
pgh_pa_guy
  • 2992 Answers
SOURCE: element 32" flat screen tv has cracked screen
Sorry to say, when the display is broken you're best off looking for a replacement TV.
There isn't any way to repair a cracked display except to replace it. You can try a Google search or check websites like shopjimmy.com that sell parts removed from junked sets. It's almost impossible to find replacement displays (unless you are a warranty servicer and get them right from the manufacturer) since most TV's are junked because of broken displays. And if you do find a display, there are still potential problems. Besides the cost (the display is the most expensive part, most of the set's cost), you need to be sure the display is exactly the same part as the one you're replacing. The same model of TV can use different displays depending on when and where it was made, and there may be differences in other parts in the set as well.
Posted on May 27, 2009
techman
  • 3130 Answers
SOURCE: vertical flickering color lines instead of pictures
Soory man there is no deflection yoke or vertical output IC in a plasma TV set.LOL This person has a problem with whats called the substain power supply or bad caoacitors in the main supply. there is also a possibility that the set has a bad tuner. Only performing test on the set will determine the problem.
Posted on Mar 23, 2007
budmrtn
  • 11361 Answers
SOURCE: 32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 17, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
westytech
  • 120 Answers
SOURCE: 32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Posted on Feb 04, 2010
Element flat screen 32 inch screen jumping and has green lines
I think if it was me I would return for exchange, refund or repair.
Dec 09, 2012 | Televison & Video
I have a solid black line across my 32' Element tv with sound,
If the line is about an inch thick, it might be due to a bad CCFL in the panel.
Jun 09, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Philips 32 inch LCD has colored vertical lines when powered on.
this sounds like a screen fault to me
try grabbing both sides of the tv and giving it a twist
this will either give you more lines or make ur lines go away if this happens u need a new screen
May 15, 2012 | Philips 32PFL3505D 32 in LCD TV
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
Open Questions:
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
