Question about Zanussi ZM24ST Microwave Oven
E14 fault keeps happening on auto defrost programme
Zanussi ZMB 32 CT microwave when auto defrost programme is used it will occasionaly show E14 fault the only way to clear this is to turn off the supply. the fault will often return before the programme is completed, yet sometimes it will work fine for days before reappearing, any ideas please. Chris Edney
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, a Zanussi ZMB 32 CT microwave is a limited European version and service documentation is nil. On other comparable models, error code "E14" would indicate a door latch/lock problem. To verify if the same error code is applicable to your particular model, on the recurrence of the same, try pressing on the door handle. The idea is to jar the door tab and engage the door lock switch/sensor and observe if the error code would no longer display. In some instances it maybe necessary to Cancel/Reset. Should this be verified, then most likely cause is a door lock switch sensor that is slightly out of position/alignment or the door itself needing a bit of adjustment on the hinge. There is no defective component. The door (and therefore the door lock + switch/sensor) being as it is, would be the most physically used component and hence would be susceptible to faults.
Should the above not address your concern, pls consult with Zanussi Ltd. Customer Care at (01635) 521313 Hambridge Road Newbury Berkshire RG14 5EP.
Good luck and Thank you for using FixYa.
Posted on Jan 03, 2009
    Genius:
  • 1,142 Answers
This seems to be a bios chip error, if the unit is under warranty then get it replaced asap or else need to reprogram the bios by some coder.
We keep getting A MESSAGE "select action 1.0lb quick defrost" which displays every 15 minutes after any function on the Advantium 120 is used.
I surmise there's a short in the Quick Defrost button on the keypad. Either the keypad has collapsed there, or some contamination has gotten in. Another possibility is a failing program memory bit in the controller chip, but a contaminated keypad seems most likely. What happens if you press and hold that button while trying to key in another instruction? Is there any change in behavior?
Oct 21, 2014 | GE Advantium 120 Convection/Microwave Oven
Keeps going to def1
You have a shorted membrane keypad.
You can find links to helpful exploded view diagrams, part ordering help, and repair help here.
I recommend that you bookmark that link to your favorites.
Nov 24, 2013 | Emerson Black Microwave Oven
I have a Zanussi chest freezer, model ZA 29 KF (old) and I have no idea how to defrost it
That question comes up many times here, so I wrote a tip about "How to defrost your freezer"
How to Defrost a Freezer
heatman101
Aug 09, 2011 | Zanussi Microwave Ovens
Where can I go to get a user manual for Carlton C17GSS09 microwave
Is thisa the 39 Pound special?
Try Curries in the UK they are cheap units made for sales as specials.
Beware tho if they break down tjhey are considered throw away.
Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
CARLTON C17GSS09 is available from as little as £39.00.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Microwave Ovens
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
Goldstar MA-1012 W Microwave
You have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
For Goldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
If you would like to have us do this for you, we do that for $39.95 plus part costs. Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 16, 2008 | Goldstar MA-1011 Microwave Oven
I don't know how to use my automatic defrost.
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318/page-25 Here is the page of your owners manual that shows how to auto defrost. It is a bit hard to read. If you have your owners manual still, it is on page 24. Hope this helps.
Jul 12, 2007 | Emerson MW8107WA Microwave Oven
Zanussi ZM24ST Microwave Oven Logo
281 people viewed this question
Top Zanussi Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Zanussi Microwave Oven Expert? Answer questions, earn points and help others
