Question about Plantronics Calisto Pro Series Cordless Landline/VoIP Phone
I have a Plantronix d150 phone the headset loses power after 10 minutes. what is the problem?
  • Plantronics Master
  • 17,115 Answers
Battery is bad
Posted on Oct 28, 2012
Do i charge it with it on, i cgarged it for 4 hours and after 30 minutes it said power off
The battery may be losing power. Charging it off will take less time and charge to a higher level.
Mar 16, 2016 | Unknown HV-800 Wireless Bluetooth Music...
My blueparrott not taking a charge can any one help me
It is actually very easy to remove the battery on the BlueParrott B250-XT. To remove the earpiece, just pull it out of the socket but be careful not to pull the wire attached to it when you separate it from the body. Next, remove the five screws to access the battery compartment. Disconnect the battery from the board and leave it disconnected for 10 minutes or so. Re-connect the battery and re-assemble. Connect the headset to your charger and after a couple of minutes, it should start charging showing red until fully charged. If it still won't charge, you may have to order a new battery. You can find a replacement battery on EBAY for around 10 dollars. Repeat the battery replacement and check to see if it starts to charge. If it works, you are good to go. If it does no work, you may have to send it to the manufacturer for repair. Good Luck!
Nov 11, 2014 | VXI Corporation Blueparrott B250-XT...
I am having a hard time pairing my Plantronics 233 with my Iphone 4...it has been saying "searching" for 10 minutes, but it is not finding my device.
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 17, 2010 | Plantronics Explorer 220 Bluetooth Headset...
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I'm trying to pair my plantronix 360 to my blackberry but the blackberry is not findind it..I had this headset paired with my old phone. any suggestions please?
I had the same problem and contacted plantronics at 1800-544-4660. apparently you are suppose hold the bluetooth goes red/blue red/blue over and over again and then it will pair. good luck!
Jan 04, 2010 | Plantronics Explorer 360 Bluetooth Headset...
Charging does not happen
I took mine back to Best Buy...I think it was a faulty bluetooth...the new one has worked for the past week...good luck!
Sep 19, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Calisto Pro Series Cordless Landline/VoIP Phone Logo
118 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
