Question about Samsung Rugby Smart 4G AT&T
How do you turn off start up sound on samsung ruby smart
Samsung ativ 500t smart tablet won't turn on after installing new battery
A lot of thing could have happened when you opened up your Tablet. Samsung makes it tough to change out batteries in Tablets.
Jun 05, 2016 | Samsung Tablets & eReaders
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Can I broadcast from my tablet to my Samsung smart TV? If yes , do I use Chromecast or what?
do you have an HDMI port on both units .if so perhaps you can change the input to hdmi 1 or 2 and do it that way .Broadcasting is not a possibility with any tablet
Feb 09, 2016 | Samsung Tablets & eReaders
Won't turn on- we bought a new battery and charger and no luck
you need to plug it in for 5 seconds,,take out charger and replug repeating this for about 10 mins.keep repeating,it will charge eventually
Feb 04, 2016 | Samsung Ativ Smart Pc 500t Tablet With...
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Tablet won't turn on
Your net power might not be sufficient; e.g. when it is like a bathroom power connection it is not sufficient
Dec 30, 2013 | Samsung Ativ Smart Pc Xe500t1c 11.6" 64 Gb...
:ptp mode samsung wb800f camera
how do i remove :ptp mode on a samsung wb800f smart
Dec 13, 2013 | Samsung WB800F Smart Wi-Fi Digital Camera...
Mijn wb800f smartcamera has frozen in ptp mode
How do turn off the PTP mode on my Samsung WB800F Smart CAMERA
Sep 18, 2013 | Samsung WB800F Smart Wi-Fi Digital Camera...
Samsung Rugby Smart 4G AT&T Logo
59 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
