Question about Whirlpool WFG361LVD - 5.0 Cu Ft, Self-Clean Gas, 2-9.5K, 1-13.5 Power Burner, 1-5Kaccusmr, Cast Iron Grates, Accubake - Freestanding Gas Range, Color - Natural Silver
Oven doesn't light when set to bake
Gas oven isn't lighting when set to Bake. All burners on range light, and the oven lights when set to Broil. I can hear the clicking when setting the oven, but it doesn't light. I'm not sure what to do, or how to check for possible problems. I am searching for my manual, but we recently moved a bunch of things and it has been lost in the mix of boxes.
SOURCE: All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Posted on Sep 16, 2008
SOURCE: Whirlpool Cooktop will not reset
Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
Posted on Dec 28, 2008
  • 70 Answers
SOURCE: Gas burners won't light
first chk the power outlet for the cook top.make sure there is 120 v.if that is ok and power cord along with the plug is ok then most likely spark module needs 2 be replaced.
Posted on Aug 19, 2009
heatman101
  • 43501 Answers
SOURCE: clicking noise doesn't stop after lighting at any
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 04, 2010
heatman101
  • 43501 Answers
SOURCE: Burners do not light consistently
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
AGR5844VDW oven not lighting
Most modern ovens have a glow bar ignitor, not a spark ignitor. It will glow a bright orange and then the oven valve will click open and allow gas through and the burner lights. Many gas ovens have a small shutoff handle located on the silver appliance regulator, which is located either behind the stove or at the bottom behind the oven drawer. Make sure it has not been accidentally closed. It will cut off gas to the oven only.
Apr 16, 2014 | Amana AGR5844VDW 5.0 cu. ft. 30" Self...
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
FGGS3045
Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Mar 08, 2014 | Frigidaire 30" Slide-In Gas Range FGGS3045
Top burners work,broiler works,oven does not
check and make sure the bake element has continuity.If there is not continuity with your ohm meter then replace the bake element.
If it tests good the replace the main Electronic control board or the oven switch which ever the unit is equipped with
Feb 23, 2010 | Cooktops
Stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jan 05, 2010 | GE Profile JGP636 Gas Cooktop
Wolf Oven
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
Aug 07, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Whirlpool WFG361LVD - 5.0 Cu Ft, Self-Clean Gas, 2-9.5K, 1-13.5 Power Burner, 1-5Kaccusmr, Cast Iron Grates, Accubake - Freestanding Gas Range, Color - Natural Silver Logo
60 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
