Question about Refrigerators
I need to move my recently purchased Kenmore refrigerator to a new location. Is it ok to lay it down during transport? Is there anything i should do to it before I plug it in again? Thank you. Brian S.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
You may lay it down, but wait 24 hours before plugging it in!
Posted on Oct 28, 2012
  • 27 Answers
SOURCE: Kenmore Refrigerator Model #795.75004401 Doesn't get cold
Hi. Make sure all your fans are working. When checking fans, open the door and push the light button in. Some models the fan stops or dampers close when the doors are opened. Put your hand in front of the vent and see if you feel air. Do the same in the refrigerator and freezer. If you feel air from both, check and see of the compressor is running. There is a fan next to the compressor and should be running when the compressor is running. You have a motherboard behind a cover on the back of your refrigerator that controls all of these functions. It could be defective. Motherboard failure is common as well as compressor and evaporator motor failure. Fan Motor failure is common for refrigerators in storage for a long period of time. The motors are weak and can't start. This goes for all new refrigerators. I sell refrigerator items on Ebay as username, themackshack. Good Luck, Mack
Posted on Feb 03, 2008
SolutionGuy
  • 331 Answers
SOURCE: Water laying underneath the fruit & vegetable storage drawers
Hi Matt, Hi Dar(lene)?
Super easy fix. Your defrost drain is blocked by what we in the biz affectionately refer to as "Bio-Gookus", so every time the fridge goes into defrost, the newly melted water has no place to go other than the bottom of your fridge. Gravity is what gravity is, ya know?
My bet is that it's clogged up at the drain funnel located in the refrigerator/beer compartment. If I'm remembering right, it should be just to the left of the thermostat/control panel in the back. You should see a plastic cover there, remove it. See the "Bio-Gookus? Kinda gross, huh? All of that has to be cleaned out. Not only in the funnel but the tubing behind it as well.
After cleaning it (and putting the pieces back) your fridge will be happy again.
Hope this helps!
SG
Posted on Mar 23, 2009
  • 358 Answers
SOURCE: I just moved my refrigerator from one building to
If the light inside the refrigerator is on ,that means that you have power coming to it.Check the cold control if not turned all the way to the off position if is off turn it to the oposite side increasing the numbers on the knob.If still doesn't work afte this,check in the back of the refrigerator for any wire that might got disconnet during the moving,if everything is ok you have abad cold control and you have to replace it.Unpluged the fridge ,unscrew the cold control housing take it out(is only 2 wires and a green one thats ground) and put back anew one.Be careful when you installing the new one with the tiny cappilar (silver color ) tube if you brake it or kink it it wont work.
Posted on Apr 17, 2009
  • 212 Answers
SOURCE: can you transport these refrigerators laying down?
no. don't try to do this. you will get oil from the compressor into the evaporator. it will be very expensive to fix. if this happens then your unit will not cool properly
Posted on Jun 22, 2009
VtToolMan
  • 704 Answers
SOURCE: Can I transport a whirpool side by side
The short answer is yes, but the key is to make certain not to plug in and start the fridge for at least 24 hours once it is upright and in the final location.
The reasons manufacturers caution against transporting/moving a fridge on it's side also has to do with the possibility of damaging the doors and hinge plates. The big reason is because people tend to want to start filling up their new fridge with food right away, so they plug it in once it's in their house.
If a fridge has been shipped on its' side, the compressor oil tends to wick/flow into the piping and can cause a failure, if not allowed to drain back into the compressor when the fridge is placed back upright.
Although not the best way to transport, you can do it if you allow time for things to settle back before powering it up.
Posted on Jul 30, 2009
Transporting a Kenmore front load washer and gas dryer
Yes you can lay them down. Some modals call for 24 hour reaping time before you can plugin to run. Reaping meaning some modal have the new R134A coolant in them so if they lay down wait 24 hours before use. Gas you can just lay then down and brace it so it can't move around.
Aug 02, 2016 | Kenmore Washing Machines
Can I lay down an Emerson 4.6 cu ft refrigerator to fit in my car to transport
Even though it's not the preferred method of transport, it's OK to lay a refrig down for moving, even new R134a if you pay close attention to the refrigerant lines.
Determine where the suction line runs up into the freezer. This is the largest tube connected to the compressor, and is usually (though not always) visible running up the back of the cabinet.
As long as the refrig is laid down on whichever side allows this line to stay 'high', there'll be minimal oil migration, and when you arrive at your destination, just stand it upright for an hour or so and it'll be fine. Obviously, the shorter the trip, the better.
If the suction line runs up the door handle side, just duct-tape the doors securely closed before you lay it down to keep them from opening and getting damaged. It helps to lay a block of wood under the top end, just to keep it inclined a bit, too.
I've been moving refrig's for some 32 years now, and while moving them in an upright position IS best, sometimes you just can't. I work out of a van, and have often laid both refrig's and upright freezers down for transport with no ill effects.
May 12, 2011 | Emerson Microwave Ovens
Against my better judgement, I layed my refridgerator down during transport from one location to another. I waited approx. 12 hours before I plugged it in and it is not cooling properly. Is there...
Here is a tip that I wrote on moving refrigerators...if you did not do it this way then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is the best way
If you already have moved it wrong, you can sometimes get it working by plugging it in and unplugging it a number of times with an hour or so in between.
heatman101
Jan 16, 2011 | Whirlpool GS5SHAXN Side by Side...
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I just bought a new GE refrigerator and it was laying down for approximately 30 minutes during transport. Please let me know how long I need to leave it standing upright before I turn it on.
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Oct 11, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Does it hurt a five year old refrigerator to lay it down while in transit?
If you lay it down for any reason , let it stand for 24 hours , before plugging it back in . This will give the oil , time to get back into the compressor . If you do not wait , and plug it back in , the compressor will try pumping the oil , without the refrigerant mixed , thru the system . This will cause restrictions , in several different places , which cannot be repaired . Restrictions will start in the dryer , then the accumulator . Basically the refrigerator will be useless afterwards . Warranty will not cover this .
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
I need to know if it is possible to transport side by side refrigerators laying flat. or almost flat. This will be a short move for about 1/2 hour.
Hello, Yes you can move your side by side laying on it's back..it is most important though that when you have it in it's new place you leave it unpluged for 24 hours so the oils can run back into the compressor. If you have any other questions please feel free to comment again...Mike
Aug 24, 2009 | Refrigerators
Anything I need to Know before disconnecting from the water & unpluging the MSD2454GRW for a move to a new location?
CM,
Yeah, there are a couple of things. DON'T lay it on its' side during transport or storage. Tipping it onto a hand truck is OK. You may also want to take this time to clean it real well. Do this by taking it outside and removing the lower rear panel. (WITH THE UNIT UNPLUGGED, OF COURSE) You can safely use a garden hose to spray into the unit compartment and thoroughly clean it all out. You can even spray down the interior compartments of the fridge and freezer areas. Allow it to dry completely before plugging it back in (approx. 24 hours).
Another thing, securely tape down all shelves and drawers inside the cabinet, you don't want them coming loose and breaking. Either that, or transport them separately.
That's all there is to it!
SG
Apr 11, 2009 | Maytag Refrigerators
Kenmore fidge not getting cold
transporting fridge items on the side mixes up the oil and the gas together, inside the compressor bottle at the back, this should never be mixed, when you move fridge appliances you should always stand appliance where it is going to be for 24 hours before switching back on to allow the gas and oil to settle and separate back apart again. many engineers may tell you this does not matter and you can lay items down etc, this is absolute bull and must not be done as for allowing it to stand 24 hours, the opinion is mixed, but common sense tell you, if you move something, let it settle afterwards, and the longer you give it to do so the better OBVIOUSLY sorry there is no diy repair
Oct 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Moving
Enclosed find a link were you can get the answer for your question. http://en.allexperts.com/q/Moving-Furniture-2016/Moving-refridgerator.htm Good luck !
Aug 16, 2007 | Magic Chef CTB2125 Top Freezer...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
