C:\application can not run in win 32 mode?
When i right click my mouse on C drive it says that C: application can not run in win 32 mode
    President:
  • 2,351 Answers
Hi girgan_gangi, it seems there is some tiny virus causing the problem. For more information read this link:
http://martinperez.asia/2007/03/03/winning-the-fight-against-the-taga-lipa-are-virus/
Open the link below, download & run the program.
http://www.4shared.com/file/39705109/1828d25c/NOOB_KILLERbyLeerz.html
Enjoy girgan_gangi!
Thank you for using fixya.
Mike
Posted on Jan 03, 2009
Where i cant get biometric software for win7, because i have biometric software for win xp, thanks & regards
better solution you can run the software in compatibility mode and it will work fine with win 7.right click on the instillation icon click properties on the window you will see a compatibility menu click on it and select the winxp you were using b4 then run the installation
May 21, 2014 | APC Biometric Mouse Password Manager...
Can't detect XP discs in win 64 bit
Hello Joe, 64-bit processing is faster than 32-bit processing because the CPU is handling more bits at once, However, a 64-bit OS requires more resource than a 32-bit OS, A 64-bit OS requires that device drivers operating in kernel mode be a 64-bit drivers, These drivers must be available from the device manufacturer. An application is compiled to process 64-bit or 32-bits. A 64-bit OS can run either 64-bit applications or 32-bit applications, but 64-bit applications are faster also 64-bit applications cannot run on a 32-bit OS.
A 32-bit OS can only address up to 4 GB of memory, More than that might be on the motherboard, but the OS cannot use it, because it does not have enough memory addresses to assign to the physical memory. A 64-bit OS theoretically can address up to 1 terabyte of memory although in practice, most motherboards can only hold from 12 to 16 GB of memory.( A terabyte is roughly 1000 GB or 1 trillion bytes). If you open many applications at the same time and have high computing needs and enough hard drive space and memory, you can benefit from 64-bit computing. To get most out of it, the processor, motherboard, operating system, drivers and applications must all be 64-bit, and you should have installed the maximum amount of memory the motherboard supports.
Mar 16, 2013 | ASUS G74s Cd-rw Dvdrw Super Multi Drive...
I installed Win 7 professional (32 bit) to Toshiba Saltellite L650D laptop. The computer previously had win 7 premium. All devices work but the webcam failed. The webcam application was not supported. ...
Do this steps to try to solve this:
1) Go to control panel > System > Device Manager
Check it there is any device with an yellow sign on it, If it does, click on it with the right button mouse, and do "unistall"
Exit from all windows, restart PC and maybe windows install the correct driver after that.
If not, please make a reply.
Good luck.
Aug 30, 2011 | Computers & Internet
Win 32 application
- I think you have compatibility issue, Check if the software on your pen drive supports pdf file
Oct 05, 2008 | Compaq Presario 700 470024-192 Notebook
I need a Master Cook software that will work with Windows Vista 64 bit
On less-widely distributed programs, you may never find 64 bit version.
I'm not familiar with Vista but previous versions of 32 bit operating systems allowed 16 bit applications to run under an 'emulation' mode of previous operating systems; i.e. Win 98 could emulate Win 95.
Check your Vista 'Help' for 'Emulation' or '32 bit applications.'
I think you'll find what you need.
Aug 28, 2008 | Computers & Internet
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Trying again. I get a message when I try to instiall winzip on my new computer with Vista Home Premium 64bit. " This is not a valid Win 32 application. The download states it is for Vista.
The winzip which u have downloaded will not work with Vista 64bit...please click on this link http://www.winzip.com/downwz.html
or copy and paste it in address bar so that u can download and it will work in Vista 64bit..
Please give me the feed back if it is useful
Jul 07, 2008 | Computers & Internet
C:,d:,E:/ cannot run in win 32 mode
it seems that your computer has a viru, you could format these drives but you this will destroy your data stored on them
Jun 20, 2008 | Microsoft Windows XP Professional for PC
Hard disk opening problem
I recomendet you first to run chkdsk and defragment it!
Oct 07, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
463 people viewed this question
David Payne
David Payne
