Question about Samsung LN46C630 46" Series 6 LCD 1080p HDTV 120Hz
Flickering strobe on display - Samsung LN46C630 46" Series 6 LCD 1080p HDTV 120Hz
How do I get the screen to stop flickering?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Type in this key word " flickering " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 21, 2016 | Sanyo Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Flickering screen for Samsung LA40R81BHX/XSG
Resolder all of your boards ,Poor Solder Connections can cause this.
Jan 21, 2013 | Televison & Video
Flickering Sanyo LCD TV
There is some dry solder/leaky or dry capacitor in the board. I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Sanyo Televison & Video
No temperature digital display in refrigerator, light working, but loosing temperature in fridge & freezer
if its a G.E. make first check the PTC overload on the compressor to make sure compreesor is operating, if this isnt,check voltages on ptc,if no line voltage here,then check for the motherboard in the rear behind a panel as this board when bad will make digital readout go out and lights strobe and you may hear a clicking noise from there also as the lights flicker or strobe this board failure can be caused from a surge within the unit by a light bulb burning out or a power surge from outside too
Feb 10, 2012 | Refrigerators
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Vizio television screen flickers like a strobe light
lcd sets use florescent tubes to light the display and, a ballast to power the tubes just like the lights in an office ceiling.
the tubes are called cold cathodes and, the ballasts are called inverter boards. replace your inverter circuit board it connects by wires to the cold cathodes so; isn't hard to find.
Oct 05, 2009 | Vizio GV42L 42 in. LCD Television
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Samsung LN46C630 46" Series 6 LCD 1080p HDTV 120Hz Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
